Thread: Pump Voltage 220V=230V?
    Jul 2015
    Houston/Texas
    5
    I finally decided to buy a 1.5 HP VSP (Variable Speed Pump). The pump says it is for 220 volts. My circuit breaker has the double breaker for the pool which makes it 230 volts. What is the discrepancy for these two different volt readings? I heard that voltage varies naturally 10 percent. I just want to verify over time I am not risking damaging the VSP? Is there a way to convert 230 volts to 220 volts? Or are they really the same thing?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Voltage 220V=230V?
    Same thing. There is a fairly large allowable variance for line voltage.
    Mark
    Jul 2015
    Houston/Texas
    5
    Quote Originally Posted by mas985 View Post
    Thank you for your fast response. This makes me feel a lot better.
    JoyfulNoise's Avatar
    May 2015
    13,198
    Lightbulb Re: Pump Voltage 220V=230V?
    Gory details (see this source)-
    Matt
