Results 1 to 18 of 18
Thread: Seeking Pool Landscaping ideas -- hot in Texas, pool has direct sun
    Eh562300's Avatar
    Apr 2015
    Austin, Texas
    9
    Hi, there. This is the second thread I have started today, the other is in the newcomers forum about pool chemicals.
    Most of our pool is in direct sunlight in the hot Texas sun. Since our pool is shallow, it gets warm. The deep end is no more than five feet. This is perfect for our needs, but we want it to be cooler. We are waiting one season before deciding if we need a chiller, a heat pump, more landscaping, etc.
    We want landscaping that will give us privacy, grow quickly, and give shade to the pool. We will also consider umbrellas that hang over the pool or any other solution you might have.
    Should we wait until spring before planting? Do you have suggestions about what to plant?
    Thank you very much for your help.
    TF-100 test kit. 25 year old free form gunnite pool by Gary Pools, we guess about 10,000 gallons, grey blue pebble plaster, Baker Hydro skimmer with basket but not filter, rock water feature, Polaris 360/F1, Pentair Clean and Clear Plus filter CCP 320, no heater or chiller (not yet, had the other one removed, will seek advice), new VGB compliant drain and new light with CFI. Depth ranges from 3.5 feet to 5 feet. Direct sun.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Seeking Pool Landscaping ideas -- hot in Texas, pool has direct sun
    Can you post a photo of the area?
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    I'm in the same situation you are. Curious what people suggest see my build post for pics.
    IG 13,000 gal, WetEdge Prism Matrix Indigo Blue, Hayward C4030 cartridge filter, Hayward Ecostar VS main pump, Hayward Tristar VS feature pump, Hayward OmniLogic, Hayward Sense & Dispense (pH only), Stenner 45MPHP22 bleach, Hayward H400FDN Heater, Hayward Color UCL lights, Pentair LED Bubblers. TF-100 XL test kit. Test Results. Build Thread.
    Palm trees, Frangipani, Hibiscus, Society garlic, Ixora, Crepe Myrtle, Gardenias, Birds of Paradise.
    Don't forget lighting
    Jul 2015
    Florida
    48
    6 months ago
    I'm a huge fan of Xmas palms. They are self cleaning. If you get more than a few frosts a year they probably won't make it though.
    current
    Here is the rest of the landscaping
    15x28 free form in ground crystal Crete
    10-12k gallons
    Hayward aqua rite TCell 9 SWG
    Hayward Maxflo VS pump
    Hayward Star-Clear C1200
    Sep 2013
    Charleston, SC
    538
    Keep in mind any "fruit" or detritus of plants you are thinking about. We have a 40' tall Washingtonia palm that is shedding tiny white flowers and tiny pea size palm fruit berries into the pool.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Remember to use the full grown size of something when planning where to put it. I have two pine trees the previous owner planted when they were very small 20 years ago but now overhang the apron and pool itself !!
    Solar Blanket, Well Water, Borax Added. 68°
    Jul 2015
    Florida
    48
    Quote Originally Posted by Kiss4aFrog View Post
    Yep. Also if the pool will be without a screen enclosure think about the leaf shed rate. Everything I planted has almost no leaf dropping characteristics.
    10-12k gallons
    Aug 2015
    Plano, TX
    217
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    Jul 2012
    Central Texas
    436
    Late to this thread obviously, but what you plan is going to need to be in direct correlation to how close it is to the pool. If you have a lot of decking, you'll need a lot of upper branch reach.
    We have no decking. Plants are right next to coping. So during the day, pool gets full sun and is a wonderful 90ish water temp. At night, when the sun angle dips, the plants at the western end start to block direct sunlight and that part becomes a little cooler. Sounds like your desires tho are different than ours as we like bath water (g).
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    Quote Originally Posted by Eh562300 View Post
    I can't offer you up any landscaping ideas at this time, but if you look at my link to Skippy's Pool Cooler in my signature line you'll see a cheap effective way of dropping your pool temps about 5 degrees via evaporation.
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    We ended up going with bamboo. Particularly what's commonly known as Green Hedge bamboo. It will get to around 25' tall. It's a clumping type so that it won't spread like a runner. When doing my homework there are many different kinds to choose from depending on what your goal is. For us we hope it to be a fast grower providing privacy and shade without dropping leaves in the pool.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you are looking for landscaping to proivde shade to the pool, its gonna be a long haul. The pool would need to be in the shade for a few hours a day in order to be of any real benefit. And it takes real big trees to provide that type of shade.
    Your best bet is to make yourself a fountain or buy one, that sprays water from a return. A couple of those and you can easily lower the temp a couple or 3 degrees. Umbrellas work good too.
    Getting back to the landscaping though, some nice landscaping around the pool does on occasion, make being hot much more pleasurable.
    Divin Dave,
    christied48's Avatar
    Aug 2013
    Allen, TX
    89
    Yep just added 2 aerators on each side this weekend and a tilt umbrella.. big differece from last weekend! Ran it till about midnight Saturday nite and Sunday the water was about 85 in the morning..88..89 until about 3pm when to got to 90. The mist blowing while swimming felt great and the high was like 106! The pool felt way better than the 93-94 it was before.. it definitely helped!
    24K gallon IG Stonescapes, Jandy VS pump, cartridge filter
    Nov 2014
    North Texas
    16
    We looked and looked for trees that met all our criteria and finally gave up. Everything got too big or dropped too much gunk. We wound up going with a large cantilever umbrella with full turn and tilt. I put it up over the pool on really bad days. All the landscaping we did was drought tolerant. Salvia, sedum, etc. We planted in July and I have had to baby (extra hand watering) even those. I put the umbrella over the plants during the worst of the afternoon. I purposely played it safe since I knew we were risking planting in these temps.
    We thought we would need a chiller too, but thankfully with our light plaster we have yet to hit 90 even on those 106 days. Running our bubblers and waterfall chills our water back down pretty quickly even though the stream isn't as fine as an aerator. Running it after sundown from 8:30 to 10:30 combined with lower overnight temps usually drops our pool 2-3 degrees. I've been pleasantly surprised considering how many horror stories I heard about summer water temps in Texas. There have even been days the kids jump in and shriek that it's cold. Definitely did not expect that as we also have full sun ALL day.
    17K freeform, IG, Primera Stone Sky Blue Treasure, Pentair DE, Intelliflo VS+SVRS, NOV 2014, K-2006, Pentair Racer, no gas in our area so pool only, no heater, will be looking at adding solar next season
    Jul 2012
    Central Texas
    436
    Quote Originally Posted by texasgal View Post
    Anything below 90 is cold in my book <G>
    Jun 2014
    Houston, Texas
    475
    We had a privacy issue and we put up bamboo. it's wonderful! You do have to keep it in check but it's totally now blocked the neighbors' windows from our yard. it took about six months.
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Aug 2015
    Plano, TX
    217
    Quote Originally Posted by DMS2014 View Post
    Definitely need a DEEP root barrier around that stuff!
