Thread: De Filter Pressure
    May 2015
    liberty sc
    12
    De Filter Pressure
    Good afternoon Folks
    We have stayright de filter / When i first took over from pool maintenance company the preasure would rise pretty quick about 10 -12 psi from initial presure back washed be ok couple days then back up , Thankfully found you guys cleaned filter completly re arranged elements like the are supposed to go added de started up worked awesome flows great , the only thing is my presure has gone up very little only about 3 psi from the initial 10 this has been approx 4-5 weeks we do keep skimmers and all related items free from leaves and such
    Should i look into any other issues or just be thankful
    Thanks
    Nobody
    32000 Gallon Freeform Ig 42" Play area 108" Slide / Dive Area
    Auto Pilot SWG RC 42 Cell / Stay Rite 53sqft System 3 DE Filter
    Vinyl Liner / Haywood Pump / Polaris 280 Cleaner with Booster Pump / TFP Test Kit / Taylor swirl
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: De Filter Pressure
    Just be thankful it's taken that long to get a 3 psi rise. You must be doing a good job with keeping the pool sanitized properly. A 3 psi rise from 10 would mean that it's risen 30% so I would backwash now as it's recommended to backwash when filter pressure rises by 25%. If it started at 12 psi, then you could wait until it hit about 15.
    EDIT: 25% recommended pressure rise
    Isolated Spa - 345 Gallons
