Thread: Need Help Choosing Automation System - StaRite SR333 Heater
    Oct 2013
    Laguna Niguel, CA
    41
    I'm helping my neighbor choose an automation system. He has a simple setup:
    Pentair Intelliflo VS
    StaRite SR33 Heater
    We are going to add a Jandy valve actuator. I have an Jandy Aqualink RS and will be upgrading to the iAqualink 2.0. Is there a cheaper or simpler automation system out there that allows for pool control from a smartphone?
    52k gal, Pebbleteck, Pentiar Intelliflo VS, Hayward Pro-Guard D.E. Filter, Raypack 407A Heater, AquaLink RS by Jandy, Aqua Rite Chlorinator x2, Hayward Turbo Cell x2, The Pool Cleaner robot
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Need Help Choosing Automation System - StaRite SR333 Heater
    I would check out the Pentair Suntouch. Not sure if you can add the smartphone module to it or not.
    Apr 2013
    Sacramento, CA
    2,769
    I haven't looked at prices but assuming your existing Jandy is not too old going with Jandy is the least expensive. Otherwise you have to replace your entire control center. So you are kind of locked into Jandy. If your system is old then it wont take the iAqualink 2.0 and then cost comparisons with other systems become relevant.
