Thread: How to find leak myself, without the leak specialists
    Sep 2011
    Atlanta Ga
    310
    I have another leak. I can call the leak guys and they will find it for $300. I would like to try to do it myself first. If the leak is in a pipe I will need them, but I have old tile and an old skimmer and I would like to use the dye test there and see if I can find any leaks. Is there a good youtube video, or any online instruction, or can someone here tell me basically how to do the dye test, or any other test I can do myself?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How to find leak myself, without the leak specialists
    There are quite a few videos on youtube. Just search. Food coloring works just fine but not as well as the purpose-made dyes. You'll need a syringe to put the dye/coloring in. If you're testing in the skimmer or return areas, make sure the pump is off when testing so you can see the dye getting sucked into the leak.
    Isolated Spa - 345 Gallons
    Sep 2011
    Atlanta Ga
    310
    Thanks for the info. I found lots of stuff on youtube, just like you said. I should have checked there before asking here.
    27000 gallons
    Pool built in 1971.
