Results 1 to 14 of 14
Thread: A TFP pic...
    A TFP pic...
    It looks like this every day with minutes of effort...this pool was BLACK when I opened it. You MUST follow POOL SCHOOL to the letter. This liner is about 16 years old. We have had two liners in the 26 years this pool has been open. It has been stained brown and orange at times. Follow the directions given here and you will get these results. A TEST KIT is a must, though...
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A TFP pic...
    Nicely done! That's TFPC for ya!
    Essential Links:
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: A TFP pic...
    that is one clear looking pool, great job
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: A TFP pic...
    Nice pool!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: A TFP pic...
    I'd dive into that pool. Looks great.
    Isolated Spa - 345 Gallons
    Apr 2015
    Quinlan, tx
    811
    Re: A TFP pic...
    Beautiful!
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: A TFP pic...
    gorgeous!
    <---my water looks like that (avatar)
    How come you have your vac hose going over the coping and not through the skimmer?
    Dolphin E10 Cleaning Robot.
    Jun 2014
    15,008
    Re: A TFP pic...
    What a joy to see these kind of posts once in a while. Thanks! Oh, and nice job by the way.
    Re: A TFP pic...
    Quote Originally Posted by borjis View Post
    gorgeous!
    I don't know any other way...
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: A TFP pic...
    If his skimmer plate sits on the basket with a vertical inlet you go from above, some are horizontal which allows you to go through weir door. And some people I've read remove the skimmer basket altogether and put the hose pipe directly into the pvc.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: A TFP pic...
    ah didn't know that.
    on mine I have to remove the skimmer basket and go through the weir door.
    If I went over the coping it might suck some air initially.
    Jan 2012
    7,264
    Re: A TFP pic...
    Yeah, it can be a moments challenge to take that water filled hose and grab it around and put it on the skimmer plate from above....but with the skimmer basket there it collects all the big stuff instead of sending it through to the pump basket and filter.
    Re: A TFP pic...
    Sucking air has never hurt my equipment. It picks back up and pumps very quickly...
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Jun 2015
    N Tonawanda, NY
    469
    Re: A TFP pic...
    It's b e a utiful!
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
