Page 1 of 14 123411 ... LastLast
Results 1 to 20 of 275
Thread: Yay, Foreclosure Pool!!!
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Hi!
    I posted in the welcome forum a little background, but as you've probably guessed from the title of this thread, my pool is in VERY rough shape.
    I went to Leslie's last week (hey, I didn't know better!) and $200+ later walked out with their Algae Free Guarantee course of treatment. I followed all of their instructions to the tee.... Still green.
    We decided it was my filter, so we scheduled a cleaning. The algae had caked on so badly, it caused the spines of all seven of my grids to buckle! So now I have 7 new algae free grids and a clean filter. The pool guy suggested I put my pump to "re-circulate" to keep the filter clean. This is where it's at now.
    That day (two days ago), I went back to Leslie's to test my water and try their algae free course again. (Again, I didn't know better!)
    I'm finished with the last chlorine portion of their course of treatment, but my pool is still green.
    Should I add liquid concentrated laundry bleach to the pool until it clears up before adding their Clear Aid?
    I figured I'd post, binge on "pool school" and get any advice while I wait for my test kit, vacuum hose, and roller vacuum head arriving Saturday (gotta love Amazon)!
    Headed to the full site to post pics! Thanks for your help!!!
    You know, green used to be my favorite color...
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Re: Yay, Foreclosure Pool!!!
    Leslie's first course of treating.
    [arghhh, pic goes here]
    Let's see if this works....
    Last edited by katierocks; 07-17-2015 at 05:00 PM. Reason: Adding photobucket link
    Aug 2014
    Northern IL
    4,615
    While you try to post pictures, (hahaha), I have some questions. What "stuff" do you have unopened from Leslie's? Can you return it if you want to? Which test kit did you order?
    Jul 2015
    OV, CA
    65
    If your avatar is your pool.. that's a big pot of pea soup!
    Go to the Pool School part of the forum and read up on SLAMing your pool this is the TFP version of shocking.
    http://www.troublefreepool.com/conte...tain-shockingl
    You'll need a good test kit to monitor the progress.
    The pros here will guide you through the process when you get stuck.
    BTW Its been years since I was last in a Leslie's, How does Leslie's guarantee you'll be algae free.. do you get your money back if it doesn't work? heh heh..
    Mark
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    what have you been using as your regular form of chlorine
    until you found TFP
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    30,414
    Hi, Katie,
    Return everything you can to Leslie's. Order a very good test kit (see Pool School) and then get ready to get your pool crystal clear using nothing but bleach. You will likely use a lot of it but you'll be stunned at the education and results you will get. We'll help every step of the way.
    Jun 2014
    15,059
    Well Katie, unfortunately you've been "pool stored". Don't worry, we all were at one time. As Dave mentioned earlier, you need a few basics to get on-track such as:
    - TFTestkits.net. Here you can order the TF-100 or Taylor K-2006. Both are great, but you'll get more reagents from the TF-100. Consider the XL option and speed stir.
    - You will need to SLAM from the Pool School - SLAM - Shock Level And Maintain. It will take a lot of liquid bleach, but you can do it. But you need that test kit to do it.
    - Don't put anything else in your water except regular liquid bleach - generic is fine from Wal-Mart of HEB. I would suggest until you receive your test kit, just add one gallon each evening. It won't clear-up the water yet, but hopefully keep it from getting worse until you receive your kit in the mail.
    - Keep this chart handy: Pool School - Chlorine / CYA Chart. You will refer to it all the time.
    For now, read-up and be very familiar with the SLAM link above, and stock-up on bleach. Your filter will not clear your water. Only fixing your water chemistry will do that, and the test kit and this site will help you accomplish that goal. It's all kinds of hot here in TX, but we'll help you convert the pea green to clear so you can get a couple good months of swimming out of this season.
    Apr 2015
    Quinlan, tx
    811
    Katie you've come to the right place and you've been given great advice to get your started. Just here to cheer you on and say you won't be sorry about testing your own water and becoming the queen of your pool instead of the peasant to the pool Store. 🏼
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Hi MarianParoo! I still have their "Clear Aid" and their "Weekly" treatment. I have NO CLUE what chemicals these are dressed up as... I'll definitely try to return them if I can!
    As for test kits, I ordered the Taylor K-2006, suggested from a lot of you in other threads
    Thank mguzzy! I'll definitely be SLAMing this weekend!!! Leslie' guarantees it by having you buy A LOT of stuff (I think you even have to buy their $30 brush!!!) and if your pool returns to green in two weeks, they'll replace their course of chemicals... after you do their water test of course. It's fool-proof, right? ::forehead smack:: I'm soooo happy to have found you guys!
    Hi Aussieta! I have been using Leslie's Power Powder Plus. ($99 for 25 lbs, which I just finished yesterday).
    Apr 2015
    Quinlan, tx
    811
    Oh girl! Bless your heart! But you're here now! And we will take care of you!
    Lisa P.
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Hi Texas Splash! Just ordered the Taylor K-2006! Glad I'm doing something right! Can you quantify "A lot" of liquid bleach? -- hahaha. Thanks for all the good info. Sounds like I've got quite a bit of reading to do!
    Aug 2013
    Arab, Alabama
    422
    If that is your pool in the avatar...oh, I would say start with 20 gallons.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Thank you!!!!! Love the "Bless your heart!"s here in TX. We're new to all that.
    Apr 2015
    Quinlan, tx
    811
    . It's in my Native Texan blood. Yep at least 20 gallons of bleach!
    Lisa P.
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Oh wow. OK. I'll stock up at Walmart and add one gallon a night until i get my test kit! Thanks!
    This is a pic of the step from day 1 of using Leslie's treatment plan.
    Sidenote: This property is sooo interesting! This end of the pool is under a car port!!!!
    When Leslie's cleaned my filter, this is what they found....
    This is what it looked like after adding Green to Clean and 5 lbs of Leslie's Power Powder Plus
    Last edited by katierocks; 07-17-2015 at 05:06 PM. Reason: working pictures, THANKS BEENS!
    Aug 2013
    Arab, Alabama
    422
    A couple of things...could you put your pool specifics in your signature line? Type of filter, type of pool, type of pump, type of pool surface, number of gallons, etc. That helps us help you! Congrats on the K2006! Hope you got the C version as it has more reagent.
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    This screams foreclosure, but I LOVE this little house. It has such a cool story... I just wish I knew it!
    This is the vis this morning. Should I remove our Polaris until we get the water balanced?
    Okay, off to "mom" for a bit. Thanks for allll your help. I'll get to reading your suggestions and adding bleach. Ask away with any Qs you have and I'll answer the best I can!!!
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Thanks! This forum is so empowering! I can't wait to get my test kit!!!
    Foreclosure --NO paperwork. Anthony Pool, gunite, built in the 70s/80s, Hayward DE filter, 1 skimmer, 1 intake (?) at bottom of pool suspected... we can't see it, TF-100 XL, Pool is ~36' l x 16' w x ~13' d (not positive on depth), Kidney-shaped, diving board, estimated 25,000 gallons?
    LOVE ANY AND ALL COMMENTS/SUGGESTIONS/ADVICE. Love you guys!
    katierocks's Avatar
    Jul 2015
    Fort Worth. TX
    101
    Hi! I've tried to update my siggy three times now and it's still not showing up. Here's what it would read:
    "Foreclosure --NO paperwork. Anthony Pool, built in the 70s/80s, Hayward DE filter, 1 skimmer, 1 intake (?) at bottom of pool suspected... we can't see it, Taylor K-2006 arrives Monday now, Pool is ~36' l x 16' w x ~13' d (not positive on depth), Kidney-shaped, diving board, estimated 25,000 gallons?
    LOVE ANY AND ALL COMMENTS/SUGGESTIONS/ADVICE. Love you guys!"
    Theeeeerrreee it is! haha. Oh geez. Can you tell I'm new to pools AND new to forums? Thanks for your patience!
  20. Back To Top    #20
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    On my computer at least your pictures are coming up as broken links. I can see your avatar but none of the pictures you posted in the thread. Not sure which method you're using. I use photobucket. I upload the pictures there and use a link they put on the picture page to copy and paste here.
    Be prepared to order some refills for your test kit (unless you got the "c" version which comes with larger bottles) the regular k-2006 will have small bottles of the stuff you use to test chlorine and you're going to be using a lot since you have a very green pool to clear up! That's just a heads up because no one wants you to be in the SLAM and run out of reagents!
    I see above that you said you got new filter grids. Do you have DE on hand already? DE filters are really great for filtering but because they are so darn good they clog up fast so you'll be doing a lot of backwashing and adding new DE. Glad to see you have a recirculate feature because that will come in handy when you can't babysit the filter.
    I love green to clean threads! I'm gonna hang out until you're sparkling and clear! Who am I kidding? I'll hang out after that too! lol
    Welcome to TFP!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
