Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 94
Thread: Sanger TX pool build
    After tons of rain in May and June our PB finally caught up to us. Not much progress as they didn't get here until 4pm today. I also have the GO Pro setup for a time lapse that I will put together when everything is done.
    SANGER, TX
    SCOPE OF WORK:
    APPROVED BUILDING PLAN
    110 PERIMETER SWIMMING POOL/708 SQ. FT/ 22,000 GALLONS
    TANNING LEDGE
    1 LOVESEATS
    GROTTO WATERFALL
    EXCAVATION:
    TRACKHOE EXCAVATION
    PREGRADE
    DEPTH: 4 6-5 PLAYPOOL
    REBAR:
    STEEL ON 10 CENTERS-5 IN STRESS AREAS
    BEAM WITH 4 BARS
    ALTERNATE BARS THROUGH THE BREAK
    PLUMBING:
    DUAL DRAINS IN POOL
    2 SKIMMERS IN POOL
    2 SUCTION / 1.5 RETURN
    7 RETURNS
    1 CLEANER LINE
    PRESSURE TESTING
    2 LINE FOR WATERFALL
    1 LINE FOR BUBBLER IN TANNING LEDGE
    FILL LINE TO HOSE BIB
    ELECTRICAL:
    JANDY POWER CENTER
    2 JANDY LITE WITH NICHE
    BONDING OF POOL, DECK, LIGHTS, AND ANY OTHER METAL ITEMS
    GFCI PROTECTED LIGHTING
    JANDY P-4 PDA POOL REMOTE
    GUNITE:
    8 TO 12 6 SACK MIX
    100% NATURAL SAND MIX
    3 YEAR LIMITED WARRANTY
    NO REBOUND IN POOL
    TILE, COPING, AND STONE
    6 WATERLINE TILE
    STONE COPING OR EQUIVALENT
    100 OF CHOPPED STONE FOR RAISED BEAM AND RETAINING WALL EXTENSIONS
    57 OF COPING FOR WALLS
    30 OF STEPS
    STEP SPOTTERS
    2.5 TALL GROTTO WATERFALL
    DECKING:
    850 SQ. FT OF STAMPED AND STAINED DECKING
    75 OF 4 DECK DRAIN PIPE
    CUSHION SAND BASE
    3.5 TO 4 THICK
    3/8 REBAR ON 18 CENTER
    TAN DECK-O-SEAL MASTIC JOINT
    PLASTER:
    WHITE PLASTER INTERIOR FINISH WITH BLUE QUARTZ
    POOL EQUIPMENT: (3 YEAR PARTS AND LABOR ON JANDY, POLARIS, AND ZODIAC)
    2.0 HP JANDY STEALTH
    460 CARTRIDGE OR DEV 60DE FILTER
    2 JANDY POOL LIGHT (LED LIGHT COLORED)
    PDA REMOTE
    6614 AP1400 POWERCENTER
    AQUAPURE SALT CELL
    POLARIS 280 POOL SWEEP WITH BOOSTER PUMP
    JANDY VALVE ACTUATOR
    TAYLOR TEST KIT
    POLE, BRUSH, RAKE
    CLEAN UP/START UP:
    FINAL CLEAN AND GRADE OF POOL AND ACCESS AREA
    START UP AND CALIBRATION OF POOL EQUIPMENT
    WATER BALANCE
    WARRANTY OVERVIEW
    POOL SCHOOL AND INSTRUCTIONS
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Re: Sanger TX pool build
    That's going to be a pretty pool, and what gorgeous land around you!
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Mar 2015
    Mendon, MA
    273
    Oh, a grotto! I love the grottos! Can't wait to watch this, keep the pics coming!
    18' to 29' wide by 37' long, 22K gal, Lagoon Free form, vinyl lined, in ground Pool with SWG, Hayward Cartridge 175 Filter, 3/4 HP Tri-Star, Gas fired 300 BTU heater
    Built Aug 2015- 20x40 26000 Gallon free form gunite, White plaster w/ 50% blue quartz, 2hp Jandy Stealth, Polaris 280, 2 skimmers,2 floor drains, 5 returns, bubbler, Grotto waterfall. 2 24" sheer decents, Jandy 48 DE filter, Jandy Aquapure PLC1400 SWG, 2 Color changing led
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Really nice pool!
    Welcome to TFP, and enjoy your stay.
    Essential Links:
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    That equipment doing your digging sure looks familiar. I'm guessing Jason is your PB?? If it is then you have one of the best in the business.
    102 Perimeter Freeform Pool, Rock Waterfall, Jandy Deck Jets, Depth 3'6" - 6', Stonescapes Aqua Blue Mini Pebble, Inpool Table, Rock Salt Decking, Jandy 2.0 Epump, Jandy 580 Cartridge Filter, Polaris 280 with booster pump, Jandy Power Center w/ PDA, Stenner Pump
    A country boy's pool build...Dean, Texas
    Mar 2015
    Las Vegas NV
    460
    This is going to be a great build to watch. Whoever dug this did a nice job.
    No auto-fill?
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,455
    A new build to watch! THANKS!
    Kim
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    Quote Originally Posted by QingGuy View Post
    No auto-fill?
    Yep. The guy that operates that trackhoe can pick up a little dirt clod with that machine. Very accurate.
    Quote Originally Posted by Clayswen View Post
    Yes it is.
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    I feel for you on the waiting. Jason lived over in Iowa Park near Wichita Falls for years, but is living back in Muenster now. He usually does around 75 pools per year and this year is especially busy. Jason has been building pools for a long time, and the crews you will see have worked for him for a long time as well. He is a good communicator, and he goes out of his way to make sure you are satisfied. Good luck with the build.
    What kind of Ford and what kind of racing?
    I've been out of racing for a while but I drag raced mustangs
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    Awesome. I've been drag racing for over 20 years, but haven't raced much in the last 2-3 years. I raced there at Denton years ago before we reopened the track in Wichita Falls. I have a 67 ford falcon that I just got done building a big block 555 this year. Still haven't ran it yet, but I may get it out by this fall. Kids sports have been eating up all my time the last few years.
    Laying some pipe!
    Jul 2012
    Tallahassee, FL
    30,455
    Nice progress! Two skimmers and all of the returns are going to make your pool so easy to keep clean.
    Kim
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    It looks like you're going to have quite a pool when all is said and done! The crews are doing a neat and tidy job so far.....
    Keep it rolling (as if you had control!! Lol!)
    Take care,
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Finally have someone out again after no one for a week and a half.
    Jul 2012
    Tallahassee, FL
    30,455
    Make sure you measure everything-high enough? Wide enough? Make sure to add 3 inches for the gunite.
    Kim
  20. Back To Top    #20
    Aug 2014
    Houston tx
    2,524
    Looks like you can shoot some hoops from your pool!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
