Results 1 to 11 of 11
Thread: Help Needed Choosing Bleach
    Jul 2015
    San Jose, CA
    3
    Hi everyone!
    I'm trying to switch from using chlorine purchased from the local pool store to bleach from the local supermarket.
    I understand that I need to find 'Regular' bleach with no additives. I didn't think that would be a problem until I visited the local supermarket. I had no idea how many variations of bleach are available and I'm a little confused.
    I have 2 products:
    The first is Concentrated Clorox Regular Bleach.
    The active ingredients listed are:
    Sodium Hypochlorite: 8.25%
    OTHER: 91.75%
    The second is Great Value Easy Pour Bleach.
    The label states that it contains Sodium Hypochlorite and contains NO Phosphorus
    It doesn't list the percentage like the Clorox brand
    What makes me nervous about this product is the label that states 'Low-Splash Formula'.
    This leads me to believe that there might be additives that aren't necessary or good for use with a pool.
    I'm also concerned with the 'OTHER' ingredients listed for the Clorox brand.
    So my question is: Can I use either or both of these products or are they both not appropriate for use with a pool.
    Any advice/links/product info is appreciated.
    thanks!
    30,421
    Re: Help Needed Choosing Bleach
    Use the Clorox....it's the right stuff.
    DO NOT use the splashless.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Buy nothing splashless......my rule is if it doesn't say 8.25% don't get it. Also don't get scented stuff.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2015
    San Jose, CA
    3
    OK. Got it.
    Thanks for the help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Hydro!
    Good to have you aboard!
    Essential Links:
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Dittos on what they said. plain old 8.25 % bleach, no splashless ,no scented, etc. The great value plain bleach and Clorox are 8.25%. I might add, check the date on the bleach, as it will lose strength over time. Most stores usually have a fresh supply, but it's always prudent to check.
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Jul 2015
    San Jose, CA
    3
    Thanks Patrick!
    Good to be here.
    Quote Originally Posted by lefty51 View Post
    That's good to know. Will do.
    Thanks!
    Jul 2014
    Hope Mills, NC
    567
    By the way, yhe other ingrediants are mostly water.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jul 2014
    Cedar Park, TX
    114
    I use the great value but not the easy pour variety. This is a Walmart brand by the way. Be sure to check their pool area. They have 10% over there that is even cheaper.
    12600 gallons, 24 foot round above ground
    Hayward Sand filter, Hayward Powerflo 1.5 hp Single Speed pump
    Jun 2015
    Phoenix, AZ
    73
    The type of Great Value you found is not the right stuff. Look better on the shelf. The type of Great Value you want looks like this http://www.walmart.com/ip/Great-Valu...fl-oz/31955545 if you rotate the container to the right, you'll see that it does list the concentration just like the Chlorox. It'll be the same in every way, but cheaper than the Chlorox.
    Wildcat's Avatar
    Jun 2013
    309
    Most Walmarts have HTH liquid chlorine in pool area, 2 gallons, 10% for $6.50-7.00, better value than bleach from laundry section
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
