Results 1 to 7 of 7
Thread: Safety pool cover
    Aug 2014
    NJ
    435
    Safety pool cover
    I want to order a safety cover and am looking at Loop Loc and Meyco. I plan on getting a mesh cover and have a grotto and rock wall so need a custom cover. Does anyone have any suggestions on which brand is better and specific hints to watch out for. Thanks.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Safety pool cover
    Hello and welcome,
    I have had a Meyco winter cover for 16 years and have been very happy with it. Just purchased a new one last summer as the first one started coming apart at the stitching ( do more to my poor handling in the early years, I'm sure)
    Ours is a mesh cover and it does let a lot of small debris slip through, but with TFP I can clear up the pool in no time when I open. Plus I don't have to worry about pumping water off the top all winter.
    Ours is a rectangular vinyl pool but ours was custom to fit around pool slide and stairs. The concrete anchors make for easy install and removal and it stays tight. Now we had to go through our pool builder to get ours, so I don't know how they are about selling direct to the customer, especially with a custom order. The neat thing is they save your cover info and all they had to do was look up the number and the new one fits like a glove.
    Don't know about loop-loc, but I'm sure they are just as good as Meyco. Hope that helps. If you have any other questions don't hesitate to ask. And again ,Welcome to TFP
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Jun 2014
    Portage, MI
    12
    We have the Loop Loc and are very happy with it. We have a kidney shaped pool with a bump out bench, so we had to custom order it as well. The pool builder installed it, so I cannot comment on the ease of that, but putting it on and taking it off is fairly easy once you get the technique down. It has held up quite nicely, especially with the winter ice and snow (I probably drain the pool a little too much in winter, but don't want to crack the ceramic tile!).
    22k gal, IG plaster pool, 1/2 hp Sta-Rite Max-E-Pro pump (P6E6C-204L), Sand Dollar Cristal-Flo 300# sand filter (CFII24), RayPak NG heater (P-R266A-MN-C), AquaRite T-15 SWG, Intermatic Hydro-King (T104P201), Aquabot Xtreme, Taylor K-2006
    Aug 2014
    NJ
    435
    Thanks guys. Just to clarify, My PB will install a Meyco cover (that is the only one they deal with) or I can get other pool companies to install a Loop Loc. Does anyone know if there is any significant difference between the two. The Meyco cover is currently more expensive than the Loop Loc, but I think my PB would match the other prices. I was told I would have a hole drilled into my paver patio every three feet for the cover to latch onto. Do these holes look bad?
    Thanks
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    How about GLI? Anyone have a GLI promesh cover?
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    lefty51's Avatar
    May 2015
    451
    Quote Originally Posted by grottoguy View Post
    Thanks
    The meyco cover has brass anchors that are embedded. They can be either pop up anchors or screw type. When the cover is removed they are flush with your deck and hardly noticeable. Mine are in my concrete deck around the pool, I am assuming it would not be a problem drilling into your pavers, as long as they are installed properly, I don't think they will split. If your pool builder does these regularly I would think he knows how well they work in pavers. Something you might want to discuss with him. I think loop loc has the same kind of anchor system, So it really comes down to price and if one looks better to you then the other
    lefty51's Avatar
    May 2015
    451
    You can go to meyco website and see what the anchor system looks like. hope that helps
