Results 1 to 20 of 20
Thread: draining pool and starting anew
    Jul 2015
    Phoenix
    27
    Good Afternoon pool geeks,
    In order to get rid of our high level of CYA, we decided the best thing to do would be to drain the pool and start a new.
    We are draining our 25000 gallon pebble tec pool tonight and refilling with fresh water. It should be full by Friday night.
    A few questions:
    What do I need to add to the pool to get it up to par?
    Send me some helpful links on what should be in my water and at what levels.
    Thanks in advance.
    For the meantime I shall be looking arounf the forum for answers to my questions.
    Jun 2015
    N Tonawanda, NY
    480
    Re: draining pool and starting anew
    Partial or complete drain?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Jul 2015
    Phoenix
    27
    Total drain.
    We plan on leaving a few buckets in there cuz those are always a pain to get out...especially with how deep our pool is.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Here is a link for the recommended levels.
    Love TFP? Become a
    TFP Supporter!
    Jul 2015
    Phoenix
    27
    Thank you!
    I could not fins that earlier.
    Ok...nothing listed for pebble tec.
    Now what?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    wetwilly's Avatar
    Aug 2010
    Southern California
    22
    In my drought stricken southern california water district, draining and refilling would be breaking the rules. You're lucky that is an option.
    24,000gal IG gunnite pool+spillover spa, DE filter, IntelliFlo VS 3050
    EasyTouch 4 + IC40 SWCG, TF-100
    Jun 2015
    N Tonawanda, NY
    480
    I'm fairly new here but would think CYA & liquid Chlorine would be 1st on the list. Will you be using tap water?
    Jul 2009
    Houston, Texas
    9,429
    Pebble Tec is considered a plaster finish for chemistry purposes. It will deteriorate if the calcium is too low and develop scale if the calcium is too high.
    Love TFP? Become a
    TFP Supporter!
    Jul 2015
    Phoenix
    27
    Not to sound like a (edited for politeness) but what else should we use? Gallons of 25000 gallons of distilled? Heehee...yes. Tap water from front and back hose.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Some people have well water, some city water so that is two kinds of tap water. Some people have water trucked in. There a many ways to get water.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    First add CYA, 30 ppm in a sock or two in the skimmer baskets. And add 3ppm bleach. Plain, unscented, NO easy pour or splashproof.
    Keep PH between 7.2 and 7.8
    The next day after you add CYA assume your CYA is at the 30ppm and chlorinate your pool according to the Chlorine CYA Chart. It is very important to keep chlorine level at target or slightly higher at all times for your CYA level. Letting it drop below minimum will leave the pool unsanitary and allow algae to grow.
    Is it a saltwater pool? If yes do this, Pool School - Water Balance for SWGs
    If you add your pool info to your signature then we can give better info specific to your pool, Pool School - Getting Started
    Here are the pages to start with.
    Pool School - PoolMath
    We can work on TA and PH in the next few weeks.
    Aug 2014
    Albany ny
    65
    I'll go ahead and say it ..... Fas dpd chlorine test....can be had on amazon for $30. And a cya test . Might as well buy the taylor k-2006. After your last thread was locked why be cute and address us as geeks?.... SMH.
    Quote Originally Posted by themamacurd View Post
    Bulk water delivery
    14x26 rectangle vinyl liner pool . 1.5 hp 2 speed tri star pump, 2 aqua genie skimmers , no main drain. 175 sq ft star clear cartridge filter. 200,000 btu hayward heater Tf-100
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Go easy now. I prefer to be addressed as a pool snob.
    A whole lot of people use well water and it makes a huge difference in what you might be starting out with in the water.
    Some people have water trucked in like kimkats said.
    So there ya go. You thought there was only one kind of water but alas there are many.
    I even saw a thread the other day about using ocean water! (that was quite an interesting debate.)
    I emailed you this link but I'm going to put it up here too.
    Amazon.com : TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD : Swimming Pool Liquid Test Kits : Patio, Lawn Garden
    That's coming up for me as k 2006 and it has free shipping because it's over $35. Does it show as free shipping for you too? (For all I know it's something about my location that makes it free.)
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2015
    Phoenix
    27
    I have a traditional tap water pool. I live in a city so we will be using city water from two garden hoses.
    I am having a hard time reading anything within the Pool School. The background is black with white font. It hurts my eyes.
    You said put the cya in a sock in the skimmer. So I assume you mean granules?
    Ya it's free shipping. But I am seeing the price at $53.99 not $35.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Yeah it comes in powder/granules and liquid. The liquid is quite a bit more expensive.
    You should be able to get the powder stuff at wal-mart for cheaper than the pool store. Wal-mart in my area carries the clorox branded pool stuff and their cya is labeled "Chlorine stabilizer"
    Are you looking at the forum on a computer or a phone or tablet? It's all shades of white light blue and grey on my computer.
    Yeah the kit shows as 54.99 for me the free shipping is because it's *over* $35 and fulfilled by Amazon. You could still try locally for a K-2005 and "upgrade" your chlorine test at some point from amazon. You'd have to buy 2 things though so I'm not sure you'd save any money because I don't know how much they sell that 2005 for in pool stores. (when they actually have it)
    Jul 2012
    Tallahassee, FL
    30,672
    I bet what Beens meant was that since the test kit is over $35 it would be free shipping.
    Kim
    DFW, TX
    24,517
    Somebody else had the black background issue recently. Something about a setting in their device. Maybe try another device, check your settings or print them, they aren't that big.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You mentioned being budget minded in your other thread, so granules is the way to go. It's about $4.00 per pound at hardware stores or Walmart in the pool section. In these locations it comes in 4lb canisters. I would suggest those.
    Oh, and your tap water is fine.
    Essential Links:
  20. Back To Top    #20
    30,432
    Themamacurd has been permanently banned for disrespect towards a moderator. It is very acceptable to be ignorant of pools and ignorant of what we teach and it is equally acceptable to disagree with what we teach.
    It is totally unacceptable to display the kind of vitriol towards ANY member of this forum that themamacurd posted to a Mod in a PM.
