Thread: Pool Math display error
    Oct 2014
    Villa Park, CA
    52
    Pool Math needs to have the Suggested FC Shock Levels results field expanded. Itís truncating the LSD. Try this:
    FC 6
    pH 7.6
    TA 70
    CH 300
    CYA 40
    Suggested FC Levels results:
    SWG: 2
    Normal: 3
    Shock: 15
    Mustard Algae Shock: 24
    Now increase CYA to 300:
    SWG: 14
    Normal: 23
    Shock: 11
    Mustard Algae Shock: 15
    If you mouse over the shock fields, the detail box correctly shows 3 digits. This happens with both IE11 & Chrome.
    20' x 40' 30,000 gallon IG Plaster with Spa, wading pool, fountain built 1993
    Pentair 011018 IntelliFlo / 2HP fountain pump / 2 HP spa jet punp / Jandy Ji8000 controller with IntelliComm II interface to IntelliFlo
    Crystal Water Aqua Clean 60 Sq ft DE filter / FlowVis Flow / Stenner DIY Chlorinator / The Poolcleaner 4-wheel / Taylor K-2006
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Pool Math display error
    Seeing as how we do not recommend to slam a pool with CYA levels that high I don't think the truncated numbers are a problem at this point, however I will pass the information along to our administrator. Thank you for your concern.
    Love TFP? Become a
    TFP Supporter!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No, it doesn't need expansion. Triple digit Cya levels for SLAM aren't even worth discussing much less changing the code in Pool Math over.
    Essential Links:
    Oct 2014
    Villa Park, CA
    52
    Thank you for the warning.
    Jul 2014
    Sacramento, CA
    241
    Quote Originally Posted by Patrick_B View Post
    I would respectfully disagree here. As an computer engineer who deals with overflow conditions occasionally, if the field showed "Error" or "N/A" or even "99", that would be fine, as it would be obvious that it was an unsupported SLAM case and lead to the user doing more investigation. But reporting a number that looks valid could lead someone to use it unknowingly, thinking how easy this SLAM should be, but when it doesn't work worst case getting frustrated and abandoning our methods altogether.
    Just MHO.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Aug 2014
    Northern IL
    4,615
    Excellent point!
