Thread: New member from Oregon
    kev350's Avatar
    Jul 2015
    Gresham , Oregon
    2
    Just got our first above ground pool an Intex 15' X 42". So I'll most likely ask a few dumb questions but hopefully a few goods ones mixed in there to.
    First question what chemicals and tools will I be needing ?
    Should I be checking the water ph once a week or more often the use will be fairly light the four of us and a few friends.
    Thanks for any and all help
    Kev
    Jun 2014
    15,004
    Re: New member from Oregon
    Hello Kev and welcome! First - no dumb questions. For chemicals, keep this handy: Pool School - Recommended Pool Chemicals. Focus on adding CYA to about 30, get PH to about 7.2-7.8, and put some regular liquid bleach in your water to keep it sanitized. FC level at about 2-3 until your stabilizer starts to build in a few days. You can use the Poolmath calculator to help you figure out how much to add.
    Most important - the right test kit. Not strips or pool store. Go to this site TFTestkits.net and look at the TF-100 or Taylor K-2006. These kits will not let you down.
    Review this info and let us know if you have any more questions. Welcome to TFP!
    This chart Pool School - Chlorine / CYA Chart will also be key to your success.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    kev350's Avatar
    Jul 2015
    Gresham , Oregon
    2
    Thanks for the help this info has provided
    Above ground Intex 15' X 42" Intex pool
