Thread: Question about Return jets
    Jun 2015
    Davenport, Florida
    14
    My pool has a main drain, One skimmer, and 4 return jets with eyeballs. i have them set to just break the surface of the water and circulate kinda push some toward the skimmer. is this a good setup, when i moved in they were all set to be under the waters surface.
    many thanks
    have learned much from this site!!
    12,500 In Ground Gunite Free Form, 1 Skimmer 4 Returns
    Screened enclosure, TF-100 Test Kit, Speedstir
    Sta-Rite 1hp Pump
    Pentair 100SF Reusable Filter
    Haywood Cl100 Auto Chlorine Feeder (currently disabled)
    May 2014
    St. Louis, Mo
    26
    Re: Question about Return jets
    I think it is. Mine is the same way and the jets push everything on the surface towards the skimmer.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Generally speaking it's best not to have them breaking the surface. Get as close to that as you can if you are making them push things to the skimmers. Having them break the surface can give you more aeration than you want. Remember too that you want good circulation in the lower areas of the pool as well.
    Essential Links:
    Jun 2015
    Davenport, Florida
    14
    I adjusted them tonight to be just below the surface and will see how it does to keeping the surface mostly clear
    many thanks
    Sta-Rite 1hp Pump
