Here are my observations relating to the flow switch / alarm on my Omnilogic:
1) I have seen spurious alarms, sometimes it seems like I've missed alarms (either "sets" or "clears"). In my case, I was pretty sure it was only the alarm notifications (i.e. the panel seemed to always be sane, but I wasn't always notified about a state change). Did you try resetting / restarting the panel?
2) I originally tried running my EcoStar around 1700RPM, but was seeing occasional flow alarms, so I bumped it up to 2000RPM and haven't seen any since.
3) If I remember correctly, there is a configuration option to specify whether you want the pump to shut off on a no-flow alarm or not. I have that set, so when I got those alarms, I'd have to manually restart the pump.
4) When I manually turn off the pump (like to empty the basket), either on the pump itself, or on the panel, I get a no-flow alarm. This clearly should be filtered out.
My take is that there are still some kinks in the firmware related to these alarms. I'd try a restart of the panel if you haven't already.....
