Thread: DE not sticking
    Jun 2015
    Tulare, CA
    5
    DE not sticking
    When adding DE I notice that it isn't sticking to my filters. When we go to clean the filters a majority of the DE is sitting at the bottom. I have a Pentair FNS Plus.
    In-ground pool (plaster), 18' X 30', DE Filter, 2 Speed Pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: DE not sticking
    The majority of the DE should drop off the grids/cartridges when the pump is off. As the DE collects more dirt it will begin to clog the grids/cartridges and be more difficult to clean. Are you seeing a problem with the quality of your water?
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: DE not sticking
    That's normal. Ideally, the DE falls off the grids completely. At the next startup, when it's all churning, the heavy stuff - sand and grit - fall to the bottom and all you have is nice fresh DE on the grids.
    Jun 2015
    Tulare, CA
    5
    Re: DE not sticking
    Quote Originally Posted by zea3 View Post
    The water quality is good. We cleaned the filters on Wednesday and when we inspected them on Thursday there was only DE on the top portion of the filters & the remainder was on the bottom of the tank.
