Results 1 to 12 of 12
Thread: Salt water system by Intex
    Jun 2015
    Louisville, KY
    5
    Hi! I am a new pool owner! My daughter and I bought an Intex pool, we also added a saltwater system. We were just wondering if u can add bleach to a saltwater system! Our pool has started turning green and we have no idea what to do! Can u still swim in this? The hose came off yesterday so I had to fill it back up and now it is green! I cleaned it yesterday as I was refilling it! Do u slam saltwater pools? Thanks for all of your help!!
    Mimi5775
    16 x 48 Intex pool
    Saltwater pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Salt water system by Intex
    Hi, welcome to TFP! Yes, you can slam a saltwater pool with bleach, it won't harm it at all. In fact, when you start a saltwater pool you should use bleach for a couple of days to get the chlorine up to the correct level. A saltwater chlorine generator (SWG) is great at maintaining chlorine levels but can struggle to reach the correct level on their own.
    To clear your pool you need to complete the SLAM process . You will also need a high quality test kit such as the TF 100 or Taylor K2006 in order to complete the slam.
    Love TFP? Become a
    TFP Supporter!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    A salt water system IS a chlorine system, the swg is use to maintain the chlorine level, so in the beginning and at any time your chlorine level is below your target level according to your CYA, you must supplement mostly using bleach.. Hope this help
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Was your SWG maintaining your chlorine level before the hose came off and you had to refill? It's not relevant to your question, just curious.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Marlajane's Avatar
    Jul 2011
    Memphis TN
    8
    I have the same set up Mimi. The first time we fill the pool up every summer I always add bleach to get the chlorine up to the target level and just maintain with the SWG. Anytime I need to SLAM I turn the SWG off and use bleach.
    I hope that helps
    MJ
    Intex above ground 16'x48' Ultra frame (5,061 gallons)
    Intex Sand filter and Intex SWG. TF-100
    Jun 2015
    Louisville, KY
    5
    How much bleach do u usually use?
    Mimi5775
    16 x 48 Intex pool
    Saltwater pump
    Marlajane's Avatar
    Jul 2011
    Memphis TN
    8
    I use the pool calculator to figure out how much bleach to use. http://www.troublefreepool.com/calc.html
    Make sure your setting up the calculator for the proper gallons that you have in your pool along with the percentage of bleach you are using. However, if your pool is already green you will have to SLAM it to get all of that nasty stuff out of the water.
    If you haven't already go study up on pool school Pool School - Pool School
    You are going to love taking control of your pool with all of the information you will be learning from TFP. You will know with 100% certainty that your pool is safe for you and your daughter to swim
    MJ
    Jun 2015
    Louisville, KY
    5
    Thank u so much!!
    Mimi5775
    16 x 48 Intex pool
    Saltwater pump
    Marlajane's Avatar
    Jul 2011
    Memphis TN
    8
    What are you using to test your water? If you don't have a good test kit yet you really are going to have to order one ASAP. I personally use the TF-100 (best value especially if you need to SLAM) TFTestkits.net
    MJ
    Jun 2015
    Louisville, KY
    5
    We don't have anything but what came with the filter. I am going to see if Kari can order one today!!
    Mimi5775
    16 x 48 Intex pool
    Saltwater pump
    Jun 2015
    Louisville, KY
    5
    Thanks so much everyone for the input! I did slam it and it looked a whole lot better today! We bought a test kit at Walmart to use until our TF 100 comes in! I appreciate all the help!! Everyone have a great weekend!!
    Mimi5775
    16 x 48 Intex pool
    Saltwater pump
    Marlajane's Avatar
    Jul 2011
    Memphis TN
    8
    Any update Mimi? I hope your over there playing with your new TF 100
    MJ
