I am trying to decide if that silt/slime in the picture I posted is sunscreen. How much sunscreen are we talking about to make a pool not sparkle? Like I said, probably only 2-3 bathers in the pool (although heavy sunscreen users) all last week and no one in the pool since Sunday. Yet just today, the sparkle was gone.
Leaving the SWG on during a SLAM is problematic. You have no real good idea of your FC consumption as it is constantly replenishing. The best way to SLAM and understand what's happening in your pool is to shut off the SWG and use liquid chlorine.
This sounds a litte madcap, but run the filter for the next 24 hours and tell us if the sparkle is back.
If so, just bump up your run time a little. If not, and there's more silt, investigate filter.
One other note...if you do have very mild iron staining and either your ph has been high or your metal sequestrant level has gotten low, its possible that what you're actually seeing is a very slight hint of yellow (iron) tint to your water, just enough to make it look different than usual.
In my own pool, I've gotten good at detecting that subtle hue change and top up the seqestrant.
Do you have ANY visible signs of algae?
I agree. I can't explain your past issues but perhaps this time it will work. Water is water, algae is algae and, used properly, chlorine kills all of itI would think I should be able to drop to an FC of 3-5 as that is what PoolMath suggests for CYA=70 and SWG.
I am leaning that way for sure.....except, why does it turn crystal clear during each of the 3 SLAMs? If it were filtration, why would the SLAM make it sparkling?
By the way, having this forum to walk me through the trouble shooting is great. I really appreciate all the dialogue and ideas.
Hmmm...interesting. Lot's of sunscreen last week as we were on vacation. Maybe 2 or 3 bathers for short periods of time during vacation. No one has been in the pool since Sunday though. The water sparkled until this morning.
I test at 8:00pm (pump is off) and again at 7:00am (before the pump turns on), I run the pump from 7:30am to 7:30pm
I've seen that black stuff appear in my pool after having just one guest swimmer with sunscreen. Fortunately 99% of the time it's just the two of us with no sunscreen so I don't have to deal with it very often.
I was going to ask if you tried running your pump/filter (SWCG off) overnight when doing the OCLT, but I see you recently did that.
I had a situation where I would pass the OCLT with the pump off overnight (like normal) but would fail if I ran the system overnight. Turned out something in the filter was eating FC. Conducting the SLAM with the system running 24/7 (SWCG off) resolved the problem.
Are you running your system 24/7 during the SLAM?
Run53 - Earlier you said "I would think I should be able to drop to an FC of 3-5 as that is what PoolMath suggests for CYA=70 and SWG." Although that is true, I think in your case you might want to target a little higher. I have read a number of folks targeting in the 7-8 range, just so they don't run into trouble. As long as you are under, let's say 15, you are fine. Really, as long as you aren't over 28, you are okay. I just wanted to give some extra margin to work with...
