Thread: Adding bleach at night..do I need to run the filter?
    Happypoolgirl's Avatar
    Jul 2015
    Kingwood, tx
    16
    I run the filter daily from 8am to 8pm. I added bleach to my pool tonight for the first time ever! Do I need to run the filter during to circulate the bleach? I've read that it is better to add bleach at night so that it can work at full strength throughout the night. I am wondering if I need to adjust my filter schedule. Thank you!
    19k gallon, in ground pool w/ raised spa, gunite, pebble sheen, Hayward Ecostar VSP, Hayward swim clear cartridge filter, Pentair rainbow chlorine feeder, Polaris vacuum w/ booster pump, Hayward gas heater, travertine coping, stamped concrete decking, sheer descents water features w/ Hayward Tristar pump, groundbreaking: March 2015, initial water fill: May 2015
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Adding bleach at night..do I need to run the filter?
    Yes. Half an hour should be plenty. Brushing will speed it up.
    Jul 2015
    Kingwood, tx
    16
    Thank you!
