Thread: cya test with the TF-100 test kit
    Aug 2014
    Saint Albans, Vermont
    19
    I'd like to get some clarification on how to read the view tube on the cya test. As an example when looking down the view tube I often think the black dot has completely disappeared. But after a few seconds I may start to see a very slight shadow where the dot is. (like I can see it and then I can't and then I see it again etc.) If this was at the 40 ppm line on the view tube by adding more test solution to get to the 30 ppm line usually is enough so I don't see that slight shadow. Would the correct cya reading be 40 ppm or 30 ppm? I think the answer is 30 ppm but since the target FC level is determined by this reading I want to be sure.
    thanks,
    Dave.
    Dave
    18x36 ~25k gal, IG vinyl, Hayward Super pump VS (IS2600VSP), Hayward sand filter S244T, Hayward CL200 auto chlorine feeder, Zodiac G3 cleaner, Pool install July 2014, TF-100 test kit.
    Re: cya test with the TF-100 test kit
    I've noticed this too. Will be interested to hear the answer.
    My pool: Sharkline Venture 24' x 52" ; Pentair Dynamo 1 HP 2 Speed Pump ; Pentair SD80 Sand Filter; TF-100 Test Kit w/ Speed Stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    The best way to perform that test is with the sun at your back and holding the vial down at waist level. From what you describe, I'd have taken that as 40.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    It is better to round up, estimate up, etc. Remember, it is safe to swim up to shock level. But, below minimum the pool is unsanitary and algae can grow. So, it is much better yo have a couple ppm more FC than it is to have a couple less.
