Thread: AquaLamp SK Bulb
    Nov 2010
    Fort Erie, ON
    16
    AquaLamp SK Bulb
    Hello everyone.
    I have a couple of Aqua/Lamp SK pool lamps in my pool and both bulbs appear to have burned out. It looks like those bulbs are basically the same as the 4" headlamps on my garden tractor. From the lamp housing, I see: 12 VAC, 15 A, 60 Watts max, Type PAR 36. The bulb has A51 moulded into back side of the glass. [I tried to upload photos but it looks like I've already exceeded my quota.]
    The local pool store has quoted me about C$45 for the Aqualamp replacement kit (PN AL 14, includes o-ring). My o-rings seem to seal fine.
    Has anyone bought automotive bulbs for AquaLamp replacements?
    19x35 Grecian In-Ground Pool
    Jandy FloPro FHPM 1.0-2CND 1.0 hp 2-speed pump
    Jandy CV460 cartridge filter
    Waterway ClearWater chlorinator
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: AquaLamp SK Bulb
    Any PAR36 bulb should work. It's recommended to replace the o-ring seal. I've reused mine. So far so good.
    Quote Originally Posted by bobodaclown View Post
    If you don't need to replace the o-rings (which usually is not really required), the bulbs are only $13 USD each for a 12 pack
