Thread: Newbie.... hayward s180t sand filter leaking like a geiser where valve meets barrel
    Aug 2014
    westfield
    60
    guessing its the o-ring? flange? both?
    if and when I get this figured out, whats the best sourse on how to get the filter system properly started again? (ie properly primed so I dont screw it up another way)
    thanks
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Re: Newbie.... hayward s180t sand filter leaking like a geiser where valve meets barr
    Open the clamp (when you shut the water from both ends), pull the valve, inspect the ring. Wipe it, wipe the possible sand off the neck's inside. If the ring us bad, replace, if not - lube with Jax.
    Inspect valve part that goes in the neck and the neck itself for cracks or other damage.
    Also make sure it is not your fittings that leak and make it look like the neck is leaking.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Aug 2014
    westfield
    60
    Morzh, did exactly what you said. Cleaned everything, put some silicone and locked it up. So far so good! (knock on wood). thanks!
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Glad it worked, good luck.
