Thread: leaking index sand filter
    Jul 2015
    Orlando, fl
    2
    This is the second year using our Intex sand filter on our 14 x 42 pool. Last year it was great. This year, it's been leaking like crazy and we can't figure out why. It's leaking from the leaf trap lid. When the filter is running, there is periodic suction and then it releases, letting water go. This happens every few minutes. When you push down on the leaf trap lid, you can literally push it down to release more water from the leaf trap area. Clearly, there's a breach in the suction but we can't figure out the flaw here. any help would be really appreciated. Im trying to post a video to show what I mean but I can't figure it out. My iPhone takes .mov files
    Intex 14 by 42
    Intex Salt pump
    Intex Sand filter
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: leaking index sand filter
    Probably a silly question, but is the rubber gasket in the correct position?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jul 2015
    Orlando, fl
    2
    Quote Originally Posted by PAGirl View Post
    Im guessing it is. We got a replacement gasket from Intex because we lost the old one. The problem stems from that I guess. Do you think I could use another?
    If I use this, will it be permanent?
    Intex 14 by 42
    Intex Salt pump
    Intex Sand filter
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by amyfl View Post
    nope, I use a little in every gasket I have, excellent product
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Did you try reseating the lid? Sometimes they go on slightly crooked.Mine had a tiny leak, I retightened it, then all was good.
