Thread: Thinking of changing from DE filter to Cartridge. Your thoughts?
    Jun 2015
    None nd
    46
    I have a ec75a Hayward pump and filter setup. This Hayward is junk from my experience so far. From what I can tell cartridge filters seem to be the way to go for any new pools. Can you guys tell me why I should or should not do this, and if I should, which filter should I get for a 25,000gal pool?
    Thanks for your time.
    Jan 2013
    Long Island, NY
    184
    Re: Thinking of changing from DE filter to Cartridge. Your thoughts?
    Not sure on the size, but mine is 100sqft, for 7,000 gallons, and was told it was oversized (which is fine by me). Oversized is the way to go, less cleaning intervals. Cleaning a cartridge is super easy, I do it once a year, when I close the pool in October. Only draw back to a cartridge is, there is no vacuum to waste function or "easy" drain function if you get a ton of rain. For your sized pool, my guess would would be 400sqft cartridge system. I'm sure an expert in sizing will chime in soon.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    All the different types of filters have their plus and minus. Really what it comes down to, is your preference for maintenance.
    Sand requires backwashing periodically and probably a deep cleaning every couple or 3 years.
    Cartridge filters do not require backwashing, but you have to take the filters out and hose them down when they get too dirty. Another downside is if you get algae, you may have to clean filters several times a day. The filter stuff REALLY well. Another downside, is you will have to eventually replace the cartridges after some years. You can expect a set to range from 200 to 300, depending on how large the cartridges are.
    DE Filters also filter REALLY well and so may need backwashing and DE replacement often, as well as grid cleaning.
    The larger the DE Filter you have, the better as you get a longer period of time between cleaning
    I have Cartridge and I like it really well. As for size, when it comes to cartridge filters, get the biggest one you can afford. The bigger they are, the less often you will have to clean them. FOr your size pool, I would recommend at a very minimum, 320 sq ft,If you can afford bigger, then you will be glad you did.
    Quote Originally Posted by Elementalwindx View Post
    Divin Dave,
    Jun 2015
    N Tonawanda, NY
    477
    What don't you like about the Hayward?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Jun 2015
    None nd
    46
    The fact that since day 1 of buying this house, it keeps getting clogged and won't let the pump run longer than 24 hours, even after giving it an acid bath and VERY complete disassembling (even taking the rods out of the tubes) and spraying down individually.
    The replacement tube nest for this thing costs $100 more than buying the complete filter already put together with tubes.
    Any particular brand in cartridge filters that are better than others?
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    How are you chlorinating your pool now? I read your other post:
    Help Hayward stops pumping. Air building up
    Did you ever perform the SLAM? Have you switched to TFP methods?
    Your filter may be clogging because the pool is often on the verge of an algae outbreak and you just don't see it in the water yet. It may be clogging due to lots of dead algae even if your water is clear.
    Since switching to TFP my DE filter requires much less backwashing.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
