Thread: New Pool--What Chemistry to Adjust First. First Time Pool Owner
    Jul 2015
    Ruby, MI
    1
    Question New Pool--What Chemistry to Adjust First. First Time Pool Owner
    I've learned a lot reading through the TFP site, but I want to ask before putting chemicals in my new pool. Here's the story:
    A friend gave me his 28-foot round AG pool. All I had to do was take it down, move it, buy a new liner, ... .... .
    I've got the pool up and filled with trucked-in water (city drinking water). The water looks crystal clear. I bought a Taylor K-2006 test kit as suggested by many here. I didn't want the pool to go without any chlorine while I waited for my kit to arrive, so I dumped in 1 gallon of liquid chlorine. In hindsight, I am not sure if this was a good idea. My test kit is now here, and here are my results 2 days after the pool was filled:
    • Free chlorine: 0 ppm
    • Combined chlorine: 0 ppm
    • pH: 7.5 (I am estimating that since it appears to my eye to be between the color for 7.4 and 7.6)
    • Total alkalinity: 80 ppm (the Taylor directions say this is "as calcium carbonate"--I am not sure if that's important)
    • Calcium hardness: 70 ppm (the Taylor directions say this is "as calcium carbonate"--I am not sure if that's important)
    • Cyanuric acid: 0
    I know I need to adjust the TA, CH, and CYA, and then look up how much FC to try to get. However, I am not sure what order I should do all this. Can I use the PoolMath calculator and adjust all of them together, or do I need to do it one parameter at a time?
    Go easy on me, please--I am a first time pool owner. Thanks in advance!
    Port Huron, Michigan
    18,000 gallon 28' round AG
    DE Doughboy Sequel 11 filter
    1.5 hp Hayward pump
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: New Pool--What Chemistry to Adjust First. First Time Pool Owner
    Welcome to TFP.
    I would add CYA in a sock to get to your desired level (see pool math link above) and add chlorine (liquid preferably) to get to your desired FC for targeted CYA.
    I think it's that simple. But do all of that fast.........you do want chlorine in there.
    Your PH and your TA look fine. I'd be focusing on chlorine and stabilizer (CYA)
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jan 2013
    Long Island, NY
    184
    The dry CYA takes time to dissolve and show up on your test, and it's relatively cheap. The liquid stabilizer is more expensive but pretty instant in dispersing in the water column. Even if you have no CYA, add some chlorine anyway.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP! Congrats on the new pool! Nice first post!
    CH is not important in a vinyl pool as long as it isn't way high.
    TA is OK for now. If your PH stays stable over the next few weeks then leave TA where it is.
    It is very important to keep chlorine at target level for your CYA at all times, Chlorine CYA Chart. Never let it drop below minimum or your pool will be unsanitary and algae will grow. Add 30ppm CYA in a sock and chlorinate your pool accordingly.
    It is also important to keep PH between 7.2 and 7.8.
    Some good reading to cover the basics
    Pool School - PoolMath
