Results 1 to 17 of 17
Thread: High chlorine consumption, cloudy water
    Jun 2014
    Kent, Ohio
    46
    Last year my water turned green, and I came here for help. You expertly guided me to clear water using the SLAM process.
    Well- I'm back.
    Our water has been cloudy, but not green. It gets a little more clear, and then a little more cloudy.
    We are in Ohio, and have had tons of rain this year. Tons
    Our moderate temperatures have kept out pool temp between 79-81 for the past 3 weeks.
    This week, I decided to take our chlorine level from 4 to 8-10 to kill any algae that may be present and get our water back to clear. Due to the fact that the water was not green, I hoped this would work.
    I started dumping lots of liquid chlorine in the pool. I've taken the level as high as 11, and never let it get under 5. I've used at least 25 gallons of chlorine this week doing this (the pool is 42,000 gallons). Now I'm wondering if I still need to slam.
    At 8AM, the chlorine was 10. At 7 PM, it was 6.5.
    My CC has remained at .5 for most of this week.
    TA 160
    CH 270
    CYA 85
    Do I need to SLAM, or can I get by without closing the pool?
    Notice the barely visible white drain cover in the bottom of this blue plaster pool.
    Thanks!
    26' X 45' peanut shaped 42,000 gallon non- SWG polished marble (Hydrazzo) IG outdoor pool 5/2014.
    Pentair Intelliflo 3HP variable speed pump. Pentair Clean and Clear Plus cartridge filter
    Pentair Ultratemp heat pump
    Pentair model 320 chlorine feeder. Ultra Pure Ozonator. Pentair Easy Touch.
    Aug 2013
    Arab, Alabama
    422
    Re: High chlorine consumption, cloudy water
    Seeing that you have used the methods described here, you do realize that you have a high CYA level, correct? I would get that level down by doing partial drains/refills. If not, you will have to maintain a shock level of 35 ppm FC. Once your water has cleared you will need to maintain 7 - 10. So, basically you need to SLAM at 35, or dilute that CYA to a more manageable level and SLAM at a lower FC level.
    When you get a chance can you post a full set of results or post a current pH?
    Also, do you use that chlorine feeder?
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Jun 2014
    Kent, Ohio
    46
    I do realize the CYA is much too high.
    Those readings are current.
    I was using Tri Chlor pucks in the feeder all summer. When the water got cloudy, I decided to let them run out and only use liquid chlorine.
    I do understand Tri Chlor adds CYA.
    Jan 2012
    'burbs of Augusta, Georgia
    7,365
    For a Non-SWG pool such as yours, and with a CYA of aprox 90, you should never be dropping to FC 5. That's going to let something grow annoyingly.
    Your absolute minimum is 7, with the target of 10, and shock level of 35.
    You say you've taken it up to 11, but have you *Maintained* it there long enough to pass the 3 criteria to end the SLAM process?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    You do need to SLAM but no need to close the pool. We SLAMed a few weeks ago and swam for hours every day. Our CYA is 70 and we had FC between 25 and 28 at all times. Chlorinate your pool based on your CYA and the Chlorine CYA Chart. It is safe to swim when FC is between minimum and shock level.
    Jun 2014
    Kent, Ohio
    46
    I e been slamming the pool for 6 days. I've tried to maintain the FC at 31 as best I could, but sometimes I have to work. I've left my automatic cleaner in the pool except for when people were swimming. The CC never went above .5, and the FC drop gradually got lower, as it should.
    Last night, I ran out of reagent. It's been 6 days of SLAM, and a ton of bleach. I never reached the SLAM goal for chlorine loss overnight, but the water is now clear, and consumption is much lower.
    What to do?
    DFW, TX
    24,502
    Get more reagent from TFTestkits.net and keep slamming until you pass all 3 tests for slam completion. Pool School - SLAM - Shock Level And Maintain
    Pool looks much better!
    May 2014
    Houston, TX
    12
    I just went through 2 failed SLAMS. On the 3 try I used higher slam numbers and stayed with it until I passed the OCLT test.
    If you don't go all the way with the SLAM the algae will come right back when FC levels drop.
    TF-100 Test Kit. 25 year old plaster in ground, 16,600 gallons pool & spa, sand filter, the worlds oldest Jet Vac pool cleaner. Pool is surrounded and covered be large live oak trees.
    Jun 2014
    Kent, Ohio
    46
    I ordered another kit yesterday.
    I'll continue to add 6-8 gallons of chlorine daily until I pass all 3 test.
    Thanks for the warning
    Jun 2014
    Kent, Ohio
    46
    Still struggling.
    The water is crystal clear. Beautiful!
    I started the SLAM 9 days ago. Due to the high CYA, my slam # (FC) is 31.
    We ran out of reagent after 6 days of SLAM, and still dumped a lot of chlorine in the pool, but I can't say exactly where my FC level was.
    We got more reagent yesterday so I was able to start testing again. I had to add 6 gallons of bleach to get back to 31. Last night at 11 I added another gallon, and then at 12:30, I was still at 31 FC. We have not swam, or taken the solar blanket off of the pool in 2 days. Our automatic cleaner is busy working under the blanket. Our CC's have registered 0 for at least 5 days. This morning at 7:30, the FC was down to 28, so I added 256 ounces of bleach. The CC was still 0. At noon it was 21.5 FC, 0 CC, so I added 5 more gallons of bleach. The water is still crystal clear.
    It seems to me like our consumption is high given the 0 CC for so long, the fact that the pool has remained covered, and the clear water.
    What are your thoughts?
    Thanks
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Stairs? Lights? Anything in the pool? Cleaner might be causing trouble.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    Kent, Ohio
    46
    I do have wedding cake stairs, 2 ladders, and a light.
    I thought the very high chlorine levels for such a long time would have killed everything alive in the pool, and the CC being at 0 for so long was proof of that.
    On the other hand, I'm still using quite a bit of chlorine.
    Other thoughts?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    remove the stairs, the 2 ladders and the light. Clean all the algae from them. Continue SLAM until all 3 criteria are met. Then put all the stuff back in.
    Jan 2012
    7,365
    Algae has this (sort of amazing) skill in that it can produce a biofilm that covers it and keeps it protected from the chlorine. That's why brushing the pool is so important as it disrupts that biofilm and allows the algae to both get in contact with the chlorine but also get it into circulation so the filter can help pick it up.
    Stairs, lights and other good hiding places are notorious for harboring algae.
    DFW, TX
    24,502
    Yep, my SLAM was the same way. My water actually was crystal clear for 3 years and never got cloudy at all. 0 CC the whole time. I foujd algae behind the light and inside my pool cleaner. Banned the cleaner and cleaned behind the light and the slam was done right away.
    Jun 2014
    Kent, Ohio
    46
    Thanks to all of you, I can count the holes on my drain cover, and even see the stairs all the way across the pool.
    Thanks!
    DFW, TX
    24,502
    Now that is a TFPC clear pool!
