Results 1 to 8 of 8
Thread: Got my kit & weirded out by my numbers
    Jun 2015
    O'Fallon, MO
    45
    Hello All,
    I posted yesterday about adding bleach & CYA until I got my TF100 kit. It arrived so I tested it. Yesterday I added about 60 oz of 10 % bleach plus the amount of CYA pool math stated-don't remember how much but it was alot-close to 8 cups. The first sock dissolved well but the second didn't fit in the skimmer so I hung it by the jet. It still hasn't all the way dissolved. Anyway, here are my numbers:
    FC, 0, yes, that's right, a big fat 0
    pH, 8.2
    TA, 240 I think, it turned pink at 24 & got slightly darker as I kept adding to 30 drops.
    CH, 225, again that's when it turned but it's more purple than blue. I added a couple of more drops & it was just slightly darker.
    CYA, i'm guessing 15 as I was still seeing the dot with the tube completely full. It was cloudy & starting to diminish so that's my best guess.
    These numbers seem really strange to me but then again what do I know about this so far, LOL! i did not do the Chlorine Drop test since it registered 0 on the FC. The CYA sock is still hanging in there, but has dissolved enough I could probably put it in the skimmer, but I'm not sure what to do. I'm not real sure about using the pool math tool just yet also, so I would love it if someone can give me thoughts & then I can play around with it making sure I'm getting the right values. On a good note, the pool is clear, the slimy bottom was gone, & there was a bit of remaining green on the sides walls. I brushed that today & have had the pump going all day. Remember, the pool had about 14 " of rainwater in it plus it took me about 3 days to fill since I didn't go full bore with our well water not having the highest pressure-still needed some house water!! Thanks again everyone.
    24 x 52 intex AG round with well water-water has no issues with rust or other contaminants
    2800 GPH Intex sand filter pump
    Located in Missouri
    Jun 2015
    Raleigh
    357
    Re: Got my kit & weirded out by my numbers
    You still need to do the five drop test to determine if you have any CC which would contribute to why your FC is zero after adding bleach. The chlorine is killing something to be at zero along with UV loss...CC will indicate how much of the chlorine has binded to organic matter.
    CYA results may take up to a week to show so just assume your CYA is at the level you added and keep your FC at the appropriate level for that CYA. Bottom line you need to add bleach and pronto.
    Lastly if you already have algae growing did you bring your FC to SLAM levels? I'm guessing not as the first step is to lower your pH to 7.2 and it's 8+.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jan 2013
    Long Island, NY
    184
    Chlorine could be zero due to low CYA level as well. Get that Alk & Ph down by adding some acid. Pool Math will let you know what to add. Dump some more bleach in as well, you don't want to start to have algae showing up.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Congrats on the new test kit!
    CH is not important in a vinyl pool, as long as it isn't way high.
    TA can be worked on later.
    CYA, good that you are adding some.
    It is very important to maintain chlorine at target level for your CYA at all times based on the Chlorine CYA Chart. It is even more important to never let it drop below minimum or your pool will be unsanitary and algae will grow. Assume that whatever CYA level you added is in the pool and set your chlorine level accordingly.
    It is also important to keep PH between 7.2 and 7.8. With your TA being high your PH will tend to rise so keep an eye on it. When it gets to 7.8 add muriatic acid to lower it to 7.2. Doing this will slowly lower your TA or you can lower it more aggressively by following this process, Pool School - Lower Total Alkalinity.
    Here is more info on Pool School - PoolMath
    Jun 2015
    O'Fallon, MO
    45
    Thanks. I did not slam. Reading the info, I should correct the TA before slamming, right? So how exactly or where should I add the acid. Should I go on & add acid plus the bleach? Can we swim tomorrow then?
    Located in Missouri
    Jan 2013
    Long Island, NY
    184
    Use muriatic acid and pour it in slowly, in front of the return with the pump running. Do not try to bring the Alk and Ph down in one dose. Do it in intervals. Let the Pool Math decide what you need and gradually bring it down in doses. Add some, let it mix for an hour or so, test and see if you need more,then add it again, test, etc... The Alk will come down with acid, but concentrate on the Ph numbers first.
    TF-100 test kit
    DFW, TX
    24,485
    No, do not need to correct TA before SLAMing. Need to lower PH to 7.2-7.4 before SLAMing, Pool School - SLAM - Shock Level And Maintain.
    It is safe to swim when:
    PH is 7.2 to 7.8
    Chlorine is above minimum and below shock level for your CYA,
    Chlorine CYA Chart
    and the water is clear
    May 2015
    Southern Illinois
    49
    I would add CYA up to 30 before slamming as well, otherwise it will be hard to keep the FC levels up to shock levels during the day.
    Edit: Never mind, I did not comprehend that you already added it, it's probably just not registering on the test yet.
    26' Intex 17k gallon above ground pool. 3000 GPH intex sand filter. Taylor Tech. k-2006 Test kit.
