Thread: First time poster, first time pool owner, with questions
    Jul 2015
    Cypress, TX
    10
    I've read through most of the information in Pool School, some of it multiple times, and I want to see if I've got this right. I've never owned anything more than a kiddie pool, so a lot of this information is Greek to me. We're starting small, with a ProSeries 14x42. I'm in the process of leveling and hope to get the pool set up soon.
    Here are my questions:
    1) After the pool is filled, I test the water and make any corrections/adjustments to the various levels, correct?
    2) Despite my warnings, my hubby went to Leslie Pools and bought some items they recommended. Some things we can use, but some I'm not so sure of. 3" chlorine tabs, I think I can use, but what about these: Chlor-Brite sanitizer (99% sodium dichloro-s-triazinetrione dihydrate) and something called Leslie's Perfect Weekly, made by Natural Chemistry (cleans water, removes phosphates, blah, blah. no actual ingredient list). From my reading and what little my brain has absorbed, I'm pretty sure I don't need or want the Perfect Weekly. Does anyone know what this stuff is or if it does what it says? I did a little googling, but didn't find much. I'm thinking of taking it back and exchanging it for a decent test kit, instead of the strips the hubby bought.
    3) The pool is at our bay house, which we visit every 2-3 days, staying for 2-3 days. I go as often as my work schedule allows. It's possible we could be away for 7-8 days at a time, but that doesn't happen often. Due to the fact I won't be testing and adjusting every day, I was thinking I'd use bleach + the chlorine tabs. Is this a good idea or not?
    Thanks for reading and for any info you can share.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,624
    Re: First time poster, first time pool owner, with questions
    Welcome. The Pool perfect is nothing more than a natural enzyme product and yours obviously has a phosphate remover built in. Neither of which is required. Take it back, get a refund, and order one of our recommended test kits in Pool School.
    May 2015
    Colorado Springs
    94
    I'm new also and luckily don't have a pool store except and hour away., lol I got the TF -100 pool kit and love it. It is so much easier using simple things and using advice form here. I can get the results and make changes easily right away with the basic chemicals like bleach and muriatic acid and Cyauranic acid (?sp) CYA from Walmart. My sister in law spent $200/mo on pool chemicals using a pool store and that was 17 yr ago.
    Used pool 1995 Lomart 18'x48" just installed 7/16/2015, Hayward Power Flo Matrix 1 HP 2 speed pump, 16" Rx Clear Radiant sand filter ( used pea gravel and zeolite) foam wall, polystyrene bottom, liner 25 gauge overlap, TF-100 test kit. Son training for 2018 Paralympics, Hoping for solar heater of some sort. Good chance Labrador will be in pool. Colorado Prairie, 6000 ft elevation high mountain desert, clay soil
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    If it isn't on this list then it isn't in my pool!
