Thread: Pump Run Times?
    Jul 2015
    San Diego, CA
    12
    Pump Run Times?
    Hi, I am running an intelliflo VS pump and wonder if it is better to run one long run (10 hours straight) vs 2 shorter ones (5 hours in am / 5 hours at night) or does it not make a difference?
    Since I am using intellichem system which automates control of chlorinator and acid injection, I'm thinking it might be better to run shorter runs more frequently to maintain constant chlorine and pH levels.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Run Times?
    Start here: Pool School - Determine Pump Run Time
    10 hours is probably way more than you need but your SWG may dictate how short you can actually run.
    But split run time should only really matter for skimming because you should never allow FC to get so low that you have to run the pump to just redistribute the remaining chlorine in the pool. That just means you did not put enough in to start.
    Mark
