Thread: Earth or Sand filter
    Jul 2015
    Freetown/MA
    3
    We are purchasing our first above ground pool. What are the differences between an Earth filter and a sand filter? Is one better than the other?
    Thank you!
    22,553
    Re: Earth or Sand filter
    They each have their pros and cons. The Diatomaceous Earth (DE) filter is supposed to filter finer material than a sand filter, but it requires adding DE after each backwash and it requires a complete teardown once a year. It also clogs a lot quicker and requires a lot more cleaning if opening a green pool. A sand filter is the easiest to maintain, but wastes a good bit of water when you have to backwash.
    Having said that, lots of people here have sand filters (myself included) and their water is perfectly clear and very sparkly. Besides, you can add a cup of DE to a sand filter if you wish.
    Personally, if something ever happens to my sand filter where I have to replace it, I'm going with a 200 sqft cartridge filter.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You picked the two extremes, sand and DE. DE = finest filtration, but most maintainence. Sand = least fine filtration, least maintainence. Cartridge is between on both counts. I suggest you read the article comparing them:
    Pool School - Pool Filter Comparison
    chiefwej
    Orlando, FL
    690
    I have a sand filter and love it. I get enough rain in Florida that I do not have to raise the level after backwashing. I typically use backwashing to drop the level in the pool. My sand filter just works with minimal attention from me. It is my longest lasting Intex equipment.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Sand is the most convenient. The pool given proper care, sand js quite adequate and should you ever need out of ordinary measures, it makes it easier.
    Just buy a proper size.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    All three types of filter have their advantages and disadvantages. There is no best type. It depends on your situation and what your priorities are.... Fine filtration, easy maintainence, less water wasted.
    chiefwej
