Results 1 to 8 of 8
Thread: Type of Chlorine to use for SLAM
    Aug 2007
    Austin, TX
    343
    Arrow Type of Chlorine to use for SLAM
    I understand that liquid chlorine is the best but what would be the 2'nd, 3'rd choices to use? Since my bulk chlorine supplier is out of business, I am wondering what the next few options are. Reading up on some older posts, I am leaning towards Lithium Hypo. I have really hard water and I don't want to add calcium. As an example, I see Leslie's has a bucket of 24 packs for $130.
    "Lithium Hypochlorite provides 35% available chlorine. Lithium does not cloud water, and it does not build up to cause scale. It is very fast dissolving. It can be added directly to any pool including vinyl-liner, fiberglass, painted or colored-plastered pools. Comes in 24, 1-lb. packages."
    Crystal 14470 Shock Lithium Hypochloride, 24 Pack
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Type of Chlorine to use for SLAM
    That lithium is awful high dollar to SLAM with.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    ok, so your supplier is out of business. why not just go to Walmart and buy the bleach then???
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    May 2015
    Chickasha, OK
    184
    I know Atwood's (and maybe even Tractor Supply) has pool chemicals -- and I'm talking 10% bleach for 2/3 the price of 8.25% at Walmart. Are there any "farm & ranch" stores nearby you could check out?
    If all else fails, Great Value bleach from Walmart worked fine for my SLAM. It just took more of it...
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Aug 2007
    Austin, TX
    343
    Trust me, I have hauled my share of cases...
    Due to my very hard water, what's the next best option beside liquid?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Honestly, all the common dry chlorines are going to raise CYA or calcium. There is mono-sodium persulfate (MSP) but I don't know if the cost will be any better. Other than a complete water change, liquid chlorine is the only cost effective way to slam the pool. Everything else is going to raise CH or CYA.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Lithium hypochlorite would be closest to chlorinating liquid or bleach in that it does not raise CYA nor CH, but of course it's quite expensive.
    Apr 2013
    North OKC Area
    300
    Yeah, $130 for 24 pounds is like paying $10 for a single 121oz jug of 8.25% bleach.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
