Thread: Seeking opinions on Salt systems Bad experience with zodiac EI products
    Atlanta, GA (Dunwoody)
    59
    I have had two of the EI systems go out with the same power board problem and the manufacturer will not warranty because it two months out side the 12 month warranty. Based on what I'm seeing on Google searches this is a common problem. Basically I have to buy a new system every year based on the part and installation cost....Just doesn't make sense..Anyway, I'm looking at the Hayward system or recommendations of reliable, quality back companies. I'm sure all systems have problems, but shouldn't cost 100s of dollars per year.
    Thaks
    Heinsite
    17500 pool/spa iAqualink Rev R, Pentair VSF, Pentair DE Filter, Waterfall, 3900 Polaris Cleaner, Goldline Saltwater Gen. w/t15, Rayvac 40,000 Gas heater, Taylor K-2006 Test Kit, Taylor Saltwater Test Kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Seeking opinions on Salt systems Bad experience with zodiac EI products
    I've been using a Goldline AquaRite (same as Hayward) system for over ten years. T-15 cell failed after 7+ years of use, which I consider to be very good. $400 to replace divided by 7+ years service = less than $57 per year chlorine cost. The only other issue I've had was a failed resistor, which is a common issue. New part <$5, ten min with a soldering iron, and it's back in service.
    Two big advantages to the Hayward: One, there are so many of them in use, that help and advice is readily available on the forums. Two, the output can easily adjusted in one percent increments.
    If mine died today, I'd buy another just like it.
    chiefwej
    jimbowrench's Avatar
    Jun 2015
    Littleton, CO
    13
    Hayward all the way. I am hoping not to jinx myself, but my cell is 8-years old, and is still going strong.
    San Juan Atlantic Deep Inground Fiberglass, 11,300 G; Pentair Clean & Clear Plus 400; Mastertemp HD 250K BTU NG; Intelliflo VST Pump; Intellichlor IC 40 SWG; The Pool Cleaner
    San Juan Royale Fiberglass, Spa 700 G; Pentair Clean & Clear Plus 150; Mastertemp HD 250K BTU NG; Whisperflo 2 HP/2-Speed Pump; Intellichlor IC 15 SWG
    Intellitouch Controls
    59
    Thanks for the suggestions. Hayward always seems to be the preferred equipment suggestion when asking here or from pool professionals.
    Heinsite
