Page 1 of 10 1234 ... LastLast
Results 1 to 20 of 190
Thread: Over my head in Wisconsin
    Jun 2007
    Milton Wisconsin
    85
    I am in over my head.
    What would you do with this?
    The good:
    Holds water and surface is in relatively good shape
    Pump, filter, and salt water system in good shape
    The bad:
    Concrete and coping are in very poor shape.
    Plumbing all leaks.
    I will likely need to tear out the existing deck/coping - replace the plumbing with 2" or better (existing is 1.5). Install a new deck/coping.
    Any recommended concrete help in south central WI?
    My hobby is my pool
    Sandissimos's Avatar
    Aug 2014
    Brighton, England
    76
    Re: Over my head in Wisconsin
    That looks like a bit of a project to me.... <<helpful>>
    12' x 24' IG approx 9.5k gallons
    4' 8" constant depth, vinyl liner, air to water heat pump, floating solar cover, 1 skimmer, 2 inlets, 1 underwater LED light, sand filtration system & now, finally, a TF100 test kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    If you have the funds, you can demo the deck and put new liner coping on it.
    If not, the a renovation of the deck might be a option. Really cant tell by the pic, but is the concrete very uneven from the ground heaving it where its cracked?
    A good power washing with a flat surface cleaner attachment will do miracles, then the cracks can be filled. It may surprise you good it would probably look.
    The aluminum liner coping could be repainted. Granted it wouldnt look new... but the the only other option is demo the deck and replace it.
    And the new liner would top it all off.
    When you mention the plumbing leaks, is it leaking UNDER the concrete?
    Divin Dave,
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    you know the decking doesn't look too bad. to refresh it you could do as Dave mentioned to clean it up and seal cracks...and then use a pool deck paint/finisher on it to make it look nice. I think you probably will need new liner coping as well.
    please elaborate on "plumbing leaks"
    that pool has a lot of potential. of course in your "con" list you didn't mention needing a new liner. is the liner still good??
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    I'm in to watch this one!
    Kim
    Jun 2007
    Milton Wisconsin
    85
    Plumbing leaks under the concrete :/
    All of the pipes tested - 3 returns and 2 skimmers - all leak under pressure bad enough it isnt effective to run.
    Bottom drain is hopeless.
    The pics dont show it well but yes the concrete is heaving and cracked pretty badly. Even if I dont replace the deck the coping is in really rough shape.
    The surface of the pool really isnt as bad as it looks - thats mostly algae from when I drained it to get a better look at stuff.
    It should clean up pretty well.
    More pics.
    https://goo.gl/photos/fzbByUnocAUA7ECK8
    My hobby is my pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum Tredge!
    Interesting project you'll have here,mane looking forward to seeing it completed. I love a good Reno.
    Essential Links:
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I would focus on getting the pool itself in order. the decking, while it looks bad, is a separate issue. most critical is getting the plumbing corrected. get the pool up and running and you can tackle the decking next year. I would just pressure wash it for now to make it look better. leaking plumbing is a bigger issue
    Dan
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    do you know exactly where the plumbing is? if so, you could do the following yourself
    demo the deck in those areas
    run new 2 inch plumbing
    plug the main drain (most pools do not have them anymore)
    clean inside the pool and get ready for new liner
    install new liner and get pool up and running
    deal with the deck at a later time
    Jul 2012
    Tallahassee, FL
    30,672
    THAT is a great plan! That way you will have a cool pool to jump into when you are working on the other part!
    Kim
    Jun 2007
    Milton Wisconsin
    85
    Quote Originally Posted by cowboycasey View Post
    Some of it - not all unfortunately. The skimmers are close to the pump and fairly easy to follow. The returns are not so easy.
    Main drain is already plugged - but how do you keep the bottom circulating with such a deep pool without a main drain? Maybe this is a dumb question but I cant figure it out.
    My hobby is my pool
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    you can aim some of your returns downward to get circulation. if you are re-plumbing might want to see how many returns you have and add a few possibly.
    Dan
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Tredge View Post
    Main drains are less essential than you would suspect. Many pools installed now do not have main drains. They are nice if you need to drain the pool but don't really help that much with circulation and water movement. If you have one return aimed down into the deep end, that is usually enough. I have 3 returns on my pool (2 at the ends, one on the side). My end returns push out across the surface to attempt to create counter-clockwise surface action and the side return is pointed into the deep end. I do have a main drain but I have a 3-way valve diverting most suction to my returns, just a bit more than a trickle to pulling at the main drain.
    Isolated Spa - 345 Gallons
    Jun 2007
    Milton Wisconsin
    85
    Update.
    I found a company that will place bracing - tear out the deck - replace the deck with concrete and a new cantilever coping.
    I still need to address the plumbing once the deck is pulled out and have some questions.
    What skimmers are best now that I have the opportunity to change them? Should I try to find the same ones or are there better options?
    Is 2 inch piping OK? Currently 1.5" Flexible or rigid? Where do I get eyeballs and parts?
    My hobby is my pool
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    Go to Midwest Pool Supply in Middleton for your pool specific parts. Install 2" rigid PVC as an absolute minimum, and you get get all that at Menards.
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    Jun 2007
    Milton Wisconsin
    85
    Another update - the project is underway - I will post progress pics as it develops.
    I decided to install a greenhouse over this pool! I refused to operate another pool without a better cover system and this is what was decided in the end.
    Pic below is not mine but is close to what it will look like.
    My hobby is my pool
    Jun 2007
    Milton Wisconsin
    85
    Progress update:
    Concrete and coping are gone. Plumbing next!
    My hobby is my pool
    Jun 2007
    Milton Wisconsin
    85
    Another update - plumbing and excavation time.
    My hobby is my pool
    Feb 2014
    Central Minnesota
    5,080
    Looking like quite the project! Keep us updated.
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,672
    Dirt! LOTS of dirt!
    Tell the "story" about the gray tube under the equipment area.
    Kim
