Thread: plastic stakes holding bottom rail in place
    May 2015
    Gulfport, MS
    109
    I am about to backfill my semi in ground pool. Am I supposed to remove those little landscaping stakes that hold the bottom rail in place? Our just leave them so the bottom rail can't move?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: plastic stakes holding bottom rail in place
    I'm no expert but it wouldn't hurt to leave them in, unless you feel they would be in a position to damage the liner if the soil around them were to shift.
    Isolated Spa - 345 Gallons
    Casey's Avatar
    SW PA
    10,448
    If your pool is full of water, you can remove the stakes. The pool isn't going to go anywhere.
