Results 1 to 8 of 8
Thread: How long to take intex 16' intex pool and safe for yard?
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Hello, how long does it take to drain*** with 2 hoses? Should I pull the drain plug and throw the hoses over the edge? Have a buyer looking at Saturday and talking about picking up Sunday... May need to borrow a sump pump I feel....
    Also is my water safe if I pull the chlorine floater and let it burn off the 3ppm?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2012
    MA
    347
    Re: How long to take intex 16' intex pool and safe for yard?
    They drain fast. You could leave the water in so the buyer could see the pool with water and drain it overnight. The hardest part is getting the last 1/2" out.
    Jun 2014
    206
    I hooked a hose to the drain port and I swear it took 2 days before.. Sorry for the title typo
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2012
    MA
    347
    I drained my 15-48" Intex last year over night. I didn't use a hose, just opened the drain. I also had the filter hoses off.
    Jun 2014
    206
    That makes sense, less restricted without a hose yea?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    I bought a sump pump from Lowes for about $80 and drained mine in about 7 hours. The last 1/4" or so, I sucked out with a shop vac.
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jun 2014
    206
    Perfect, did you need to buy a hose for sump? Thought about that too, how long the shop vac take? Got a 6 gal
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    If you have a vacuum hose you can siphon pretty darn fast with that. Just have to have a way to keep it in place as the weight of the water in the hose will try to pull it right out of the pool.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
