Thread: Hayward star-clear residential vs public GPM
    Jul 2015
    Florida
    48
    Sorry wrong forum. First timer..... Delete.
    15x28 free form in ground crystal Crete
    10-12k gallons
    Hayward aqua rite TCell 9 SWG
    Hayward Maxflo VS pump
    Hayward Star-Clear C1200
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Hayward star-clear residential vs public GPM
    You may be mis-understading the flow rates. 120 is probably the max its designed to run.
    There is no reason whatsoever to run the pump that fast for normal pool filtering.
    Your pool specifics and rest of your system will determine what your minimum flow rate will be - but since we've no knowledge of any of it, we cant make a recommendation.
    I generally run my VSP so that I get about 30 gpm. This keeps my Saltwater generator happy, and provides enough flow for the skimmer to do its thing.
    Divin Dave,
