Thread: How to setup Jandy One Touch cleaner
    Jul 2015
    Philadelphia, PA
    6
    Hi TFP, I recently moved into a home with a pool and you have been a huge help getting myself started! But I finally hit a wall and I am not sure how to proceed.
    My home has a Jandy One Touch system installed and most of the functions seem to have been properly setup. But I am not sure how to use the "cleaner mode" that the previous owner had configured. They left behind some crude drawings which helped me in the beginning, and I went ahead and drew a diagram of my pump setup. I have a Jandy Ray Vac which isn't that great, but I cant afford anything better right now. The pool is a 27,000 gallon plaster pool. It has 4 pool returns: 1 in the deep end for the cleaner only, 2 right next to each other in the shallow, and a spa return. I can turn the deep end and spa return on/off using the valves below.
    The instructions that they left me were:
    1) Connect RayVac to cleaner port in pool
    2) Put pool into filter mode
    3) Adjust valve after the pump (#4) until the gauge on the Jandy Energy Filter reads 20psi
    But it seems strange that there is a Jandy controlled valve (#5) inline with the Jandy Energy Filter.
    - What is its purpose if I need to adjust the valve ahead (#4) of it to the proper pressure?
    - Is it safe to adjust the valve after the pump (#4) so that the JEF reads 20psi, and then leave Valve #4 in that position and use the electronic valve (#5) to open/close the cleaner outlet?
    - Why would they have built the pool with the only deep end return being pre-filter?
    My goal is to leave the Ray Vac in on the week days and run it for 2-3 hrs every other day.
    Jul 2015
    Philadelphia, PA
    6
    Re: How to setup Jandy One Touch cleaner
    any advice?
