Thread: Using the Sample Sizer
    domct203's Avatar
    Jun 2015
    CT
    3,578
    I have noticed that when using the sample sizer for 10ml that I get a "dome" of water at the top of the test tube.
    I was wondering if other sample sizer users shake that off or leave it?
    I noticed that if I leave it, the sample is just above the marking on the tube, if I shake it off the level will be just below the marking.
    To get consistent results I have been leaving it.
    I know it's a small amount, and most likely trivial, I'm just curious how others go about this.
    Here's a pic of that "dome" of water.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Using the Sample Sizer
    Trivial, but shake it off. It should be part of the sample size, not stuck on the sizer
    Essential Links:
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Quote Originally Posted by Patrick_B View Post
    Thanks!
    Dom
    Dom - TFP Guide
