Results 1 to 7 of 7
Thread: separate cyliders for FC vs TA/CH
    Jul 2013
    North Canton, OH
    192
    Why does the TF100 come with a cylinder for chlorine only?
    I am ordering a sample sizer, and it says it works with the Taylor cylinders, not the ones that come with the TF100. I am also ordering a speed stirrer which comes with one cylinder. Do I need a second Taylor cylinder so I can continue to separate the chlorine testing from the alkalinity and calcium testing?
    also what is the $ limit for free shipping on TFTestKits.net?
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: separate cyliders for FC vs TA/CH
    If you use the sample sizer, you ought to have a second cylinder. I don't bother with my sizer. I think it was a waste of money. The speedstir wasn't, nor were the extra stirbars. I use the original two cylinders for FC and TA, the one that came with the speedstir for CH, and the mixing bottle for CYA. They all fit on the speedstir and with 4 stirbars, I can run every test before I have to wash dishes. If the free shipping offer is still on, I believe it's $80.
    Jul 2013
    North Canton, OH
    192
    Why separate the FC but not the CH and TA?
    38,524
    Because the chlorine test can slowly discolor the cylinder. Although you can clean it occasionally with diluted muriatic acid.
    Jul 2014
    Hope Mills, NC
    569
    My chlorine test cylinder is already cloudy after less than 1 year. Also, I have used a cylinder on the speedstir to mix the CYA test sample...not a good idea, that stuff makes a mess of the clear cylinders!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jul 2012
    Dallas, TX
    179
    I think I recall in another thread where someone mentioned using a 3:1 dilution ratio. If I use Muriatic Acid, is it best to use the diluted mix and let the Taylor vial sit for a few minutes to wait for the cloudy stain to dissipate?
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Mar 2007
    San Rafael, CA USA
    12,082
    Concentrated chlorine in the chlorine cylinder usually clears it for me. Of course, you have to very thoroughly rinse afterwards to remove that chlorine (fill, rinse, empty with water 7 times).
