Thread: Going away for week- ph question
    May 2015
    Monroe/NJ
    76
    Hi all-
    FC 5 pH 7.5 TA 80 CH 475 CYA 80
    New plaster pool still 'curing'. Have to add 3 cups muriatic acid every 2-3 days to keep pH between 7.5 and 7.8
    Going away for week. Don't feel comfortable asking neighbor to handle acid for me.
    DO I over compensate and bring Ph low and have it float back up to normal over the week, or do I let pH go high and push it back down when I get home?
    In other words what's worse, a low pH or a high pH?
    I know acidic water no good for pipes ad equipment but worried about scaling with a high pH and a CH of 475.
    Not worried about chlorine- I have a SWG.
    Thanks all in advance!
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Going away for week- ph question
    Take it to 7.2 just before you leave, and it will be fine. And it doesn't sound like you have much choice anyway. If it were me, that's what I would do in your shoes. Pipes are PVC, so no worries there at all.
    Essential Links:
