Thread: Variable pump Question
    Jul 2015
    Patterson, Ca
    18
    What is the purpose of a variable pump. I'm trying to understand my new build better. While dealing with some deck drain issues with the builder. I have questions about how it works with my cleaner mode pool mode on n running my water feature without putting the strain on my skimmer. Noticed one day with vacuum out n running at cleaner speed.Skimmer ran low an let air in at times. And I filled pool with more water more than recommended. Thanks for all n any input.
    17k g, IG free formed, plaster/bella blue,varaible pump, cartridge filter, with water feature.New build 6/17/15 builder set start up and pump filter cleaning time. Runs 12am-2am clean cycle runs 2750 rpms n from 2am-8am 1200 rpms
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Variable pump Question
    Unfortunately, this is a downside of having to power a cleaner, but you do have to make sure water level is good. Not much else I can suggest, I'm sorry.
    Essential Links:
    Jul 2015
    Patterson, Ca
    18
    But is it to run 2 or 3 separate speeds. So I can have a set rpm for pool mode, cleaner, and when I need a lil higher than 1200 rpm to run my sheer wall feature please any feed back
    Jul 2009
    Gonzales, La
    220
    Do you have deep end suctions to the pump? If so are they controlled by separate valves. If so you can open up on the deep end suctions more to pull more water from bottom of the pool.
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    Jul 2015
    Patterson, Ca
    18
    Thanks I got all the info I wanted to set 3 speeds and I did hooking my device, pump to my #1 aux. Thanks again
