Results 1 to 8 of 8
Thread: Stumped with Algae
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Stumped with Algae
    Let me start off with my test results.
    FC 5
    CC 0
    CYA 25-30
    PH 7.4
    TA 100
    I go out today and there is visible algae on the walls and floor of the pool. I always dose chlorine to about 8 and it drops to around 5 in two days. My target FC is 4. It never goes below that. I have no idea how algae is growing. I test my water every other day. It never shows any CCs. I am conpletely stumped as to how this happened. I did lose power for a week a couple weeks ago but i kept the chlorine high around 8-10, brushed the pool daily and made the family get in daily to move the water around. Again, never registered any CCs in the water. Circulation looks good as I watched a leaf floating near the bottom and it was moving all over. How is this possible?
    Does a solar cover promote the algae growth? You guys always said if you keep the chlorine levels right algae cant grow.
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Stumped with Algae
    Lower the pH a little to 7.2 and time to slam, I can't tell you why that happened but I think this is the solution...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Some times bad things happen to good people.........................but at least you know how to easily fix it.
    30,421
    Very likely you have some areas of poor circulation so the algae doesn't get into the "mainstream" of chlorinated water.
    Still true. Somehow, sometime and someplace(s) chlorine got too low and algae got as foot hold.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Bummer! Yes, looks like you are doing all the right things. What about brushing? Check behind the light if you have one. It is possible to have localized areas with low FC, that is why brushing is important.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    I've been brushing every couple of days. Do you keep ur returns towards the surface to move stuff into skimmers or towards the bottom
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I move mine around every couple of weeks
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    DFW, TX
    24,492
    I keep mins pointed more up to skim. We have lots of trees and try to keep debris skimmed. Have suction set to about 80% skimmer and 20% bottom drain.
