Thread: TA - 250 How do I lower this Need Help New to doing this - I am Using 6-way test Kit
    Jul 2014
    el paso tx
    17
    I just filled the pool 3 days ago, using the 6 way test kit this is the results
    I thought I had done something wrong this morning when I tested for TA - I got same results this evening.
    FC - 0 per pool math going to add 76 oz bleach
    PH - 7.5 ok
    TA 250 I don't know what to do
    splash superpool, 12 x25 6700 g ,vinyl, Star Rite sand filter, test by pool store
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,592
    Re: TA - 250 How do I lower this Need Help New to doing this - I am Using 6-way test
    Test your fill water also.
    Here is a link on how to lower it.
    Pool School - Lower Total Alkalinity
    Kim
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Quote Originally Posted by marymarm View Post
    PH - 7.5 ok
    What FC level are you targeting? What strength bleach?
    What are your plans for stabilizer CYA?
    Why the concern over your TA? Are you having pH issues?
    You should be more concerned with getting a better test kit.
    Anyhoo, a trip to Pool School is in order. IMO unless you are having trouble maintaining pH your energy would be better spent getting a steady FC level.
    http://www.troublefreepool.com/conte...tal-alkalinity
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2014
    el paso tx
    17
    Thanks Kim, I will look check link out.
    Dom, I am new to using BBB and testing and taking care of the pool. I will check out Pool School. Scared that I will miss up and the pool water will get bad. Don't want to fail.
