Thread: Pentair Whisperflow to Intelliflo VS
    Oct 2013
    Laguna Niguel, CA
    41
    I have a Pentair Whisperflo pump. Previously, I swapped the one speed motor out for a two speed. I just purchased a new Pentair Intelliflo VS. To avoid replumbing, can I follow the same process and use the new Intelliflo motor/impeller with the old pump/housing?
    52k gal, Pebbleteck, Pentiar Intelliflo VS, Hayward Pro-Guard D.E. Filter, Raypack 407A Heater, AquaLink RS by Jandy, Aqua Rite Chlorinator x2, Hayward Turbo Cell x2, The Pool Cleaner robot
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pentair Whisperflow to Intelliflo VS
    Yes but you should use the diffuser too because the Intelliflo uses a larger one.
    Mark
    Oct 2013
    Laguna Niguel, CA
    41
    Swapped in the Intellifo, super easy and working perfectly. Thx for help.
