Results 1 to 10 of 10
Thread: SWS on vacation?
    georgiadawg's Avatar
    Jul 2014
    Eastanollee GA
    93
    SWS on vacation?
    Hi, we are leaving for the beach for a week soon. We are covering the pool. As long as all my levels are good, do I turn off the SWS or leave it on while we're gone? We are leaving the pump running because you can't put it on a timer. It is one of those you have to manually turn back on if it gets turned off.
    Lisa
    Northeast Georgia Pro Series above ground circular metal frame set pool 22' x 52". 11,400 gal capacity. w/ Skimmer plus 2000 pump/filter. Cartridge filter (Type C)
    Intex Krystal Clear Saltwater System Model CS8110
    Jun 2014
    Roseville, CA
    343
    Re: SWS on vacation?
    In your case I'd chlorinate, cover, and shut off the pump and SWG system.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Jul 2014
    Eastanollee GA
    93
    Leave the pump off for over a week?? No circulation?
    Lisa
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Can you bring it up to shock level and then cover, leaving just the filter running?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Take FC to SLAM level, cover, run JUST the pump if you can. Got any friends to check on it?
    Jul 2014
    Eastanollee GA
    93
    No. Out in the boonies. No close neighbors or friends, family I could ask.
    So. Tomorrow, take the FC to 31. Cover it. Leave pump running and SWS OFF, correct? Just curious....right now my FC is about 10 (had to raise it slightly after heavy storms and lot of debris). Is that not sufficient if the pool is covered? Will the FC break down that much with no sunlight?
    Lisa
    Jan 2012
    7,338
    Quote Originally Posted by georgiadawg View Post
    Its just better to take it up higher, in case of any delays getting home or something getting in under the cover.... a little more protection, capisce?
    When you come home the FC will have dropped some, but just taking the cover off and exposing it to sunlight will aid in bringing it down again. You can swim up to SLAM level so no delays there....
    Have a great Vacay!
    Jul 2014
    Eastanollee GA
    93
    Gotcha. Thanks for the info. And, when we get back, leave SWS off until FC drifts back down to normal?
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yep, good plan. Beach! Woohoo!
    Jan 2012
    7,338
    Yeah, why make the chlorine generating hamsters run that wheel when its not needed?
