My spa led light went out about 6-7 months ago, I didn't mind it but now the pool light is out too.
I can hear the relay clicking, the spa light is very very dim almost gray, and the pool light doesn't light up at all.
I did some research and found that there is a 120V light for each, and a 12V light for each. I contacted Jandy on how I can tell which is which, since none of the pool documentation was here when I bought the house, and they said you can't tell I have to call someone. Don't really feel like doing that yet.
Pool(Large) Light 12V - R0474000 - CPLVLED
Pool(Large) Light 120V - R0474100 - CPHVLED
Spa(Small) Light 12V - R0473900 - CSLVLED
Spa(Small) Light 120V - R0473900 - CSHVLED
I am wondering is there a way I can tell what the light's voltages are, I was asking Jandy if I could pull the light and tell without taking the gasket off, that is when they told me to call a technician.
I can do that (take the gasket off), but then I need to order new gaskets just to take the lights out to see what Voltage to order (if one can even tell that way), put the old lights back in with new gaskets, then order more new gaskets and the correct light engines (That is my plan if all else fails).
THANKS!
THANKS!
