Thread: Pool vacuums 101
    Jul 2015
    Scotch Plains, NJ
    33
    Pool vacuums 101
    If I don't have a Polaris hookup, can I still use a robot vacuum? This may sound like a dumb question, but I've never owned a pool before, so there you go.
    Thanks.
    1964 Sylvan 18' x 46' in-ground - 32,000 Gal - re-plastered June 14, 2015, Diamond Brite quartz plaster - Hayward DE 4820 Filter - 1.0 HP Emerson motor with a Hayward super pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool vacuums 101
    Robot cleaners require no special plumbing to run. They run only on electricity. All you need is a GFCI outlet that you can plug the robot's power supply into near the pool. Each robot comes with it's own power supply. It's similar to a vacuum with a cord that you'd use in the house, but obviously is self-propelled. There are also wireless versions that would run much like a robotic vacuum cleaner with no power cord, but I have no experience with those.
    Isolated Spa - 345 Gallons
    Jul 2015
    Scotch Plains, NJ
    33
    Great, thanks. That was the answer I was looking for.
