Results 1 to 13 of 13
Thread: Cleaning the basket at the pump question
    Jun 2015
    Wheatfield, IN
    37
    I would like to clean the basket on my sand filter. I made the mistake of taking the lid off once before, that was a wet mess lol. I have one of them rectangle covers to go over the skimmer opening on the inside of the pool, so that would stop water from that side. Is there a setting on my valve that would also keep the water from coming from the return side?
    Just want to clean out the basket and put some petroleum jelly around the seal of the lid so it goes on a little easier.
    18' round above ground est 8600 /gal with Hayward sand filter filled with well water
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cleaning the basket at the pump question
    Don't use Vaseline, as it will ruin the gasket. Silicone lube would be ok. If you have a multi port valve, put it to closed. Or perhaps install a valve on the return if you need too.
    Essential Links:
    duckhunter27's Avatar
    Jul 2013
    Dannebrog, Nebraska
    59
    A tennis ball or some sort small ball works great in the skimmer. Just make sure it little bigger then hose.
    24ft x 52in Round AGP Heritage pool Aquamaster 19 in sand filter & 1 hp pump. Clear Solar blanket 12 Mil. TF-100 Test Kit. Pool filled June 3rd 2013 well water.
    mas985's Avatar
    Pleasanton, CA
    11,737
    A ball valve on the suction and return lines would make life much easier.
    Mark
    22,544
    Also some multiport valves have a closed position. You could put it in the closed position and put the cover on the skimmer and you'd only get a little water out the strainer when you took the top off.
    Jun 2015
    Wheatfield, IN
    37
    Alright, closed will keep it from coming in from the return. I'll do that then.
    Jul 2015
    Wall, NJ
    9
    A closing plug in the skimmer and another in the return will stop the flow from both ends
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    Whittle a potato and use that. That's richard320. Works well.
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Inflatableman1 View Post
    Sounds discriminatory to me. What do you have against Cucumbers, or Squash?
    Essential Links:
    Jun 2015
    62
    Busted me, the veggie racist !!
    Ryan
    Jun 2015
    Wheatfield, IN
    37
    I have a darkbuster light so the return is more of a slotted spray, not just a circle.
    30,413
    Post a pic, please. we'll get it solved for you.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I was getting confused, but that's because I'm an in-ground bigot....
    Bronzeback5 has an above-ground, so he's got to set the filter to closed AND put a tennis ball in the skimmer hole. Think I get it now.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
