Thread: Thanks TFP
    Hot6's Avatar
    Jun 2014
    Alabaster, AL
    27
    Thanks TFP
    I just wanted to check in and mention the SLAM process works as promised. My pool started to cloud up on July 3rd. I cranked up the SWG to 24/7 max output but we had a bunch of folks over for the 4th and the green tide rolled in by the 5th. On the 6th I started the SLAM. I could tell it was working but my wife could not in fact by the 8th she wanted me to drain and refill. I told her we needed to be patient and by the 10th my pool was crystal clear.
    IG Vinyl 18x36 28500 Gallon SWG Taylor K2006 Test Kit
    380 Gallon Master Spa Chlorine for sanitizer
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Thanks TFP
    Way to stick with the process and congrats on taking control of your pool!
    Isolated Spa - 345 Gallons
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Thanks TFP
    good job, now just keep up on your FC levels and testing and never do it again! enjoy that crystal clear pool!
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2014
    15,205
    Re: Thanks TFP
    Congrats on the pool and convincing the wife to be patient. Not sure which is more commendable. Bwwahaaaaa.
