Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Kids will want to swim in 4 hours.....HELP please.
    Jul 2015
    Canada
    16
    Question Kids will want to swim in 4 hours.....HELP please.
    OK:
    Just filled and installed a new 16 x 4 AG coleman vinyl pool.......roughly 5700 gallons. Cartridge filter and 1500 gph pump.
    Any way, I have a floating chlorine DUAL ACTION puck in the pool currently (roughly 28 hours in pool so far).
    MY PROBLEM:
    I have no "good" test kit until I order one and get it on weekend. SO I have bought the HTH 6 way test strips and a cheap PH/CL vial type tester.
    I have just tested my water:
    Strips say: FAC:0, TCI:0, ALK:40, PH 6.8, TH 100, CYA 0.
    VIALS SAY: PH 7.6, CL <0.2.
    I HAVE A JUG OF 10.3% bleach AND I just bought a container of CYA granules.
    WHAT CAN I DO immediately so that the kids can swim in 4 hours?????
    Thanks....Big Time.
    Jan 2014
    Buckeye AZ
    807
    Re: Kids will want to swim in 4 hours.....HELP please.
    that's a big difference between a pH of 6.8 and 7.6, the latter being acceptable for swimming, but the former may cause irritation. Hard to make a recommendation with wildly varying results.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    22,537
    I'd retest the pH and see if maybe it was just a one time testing error.
    Follow the instructions on the strips exactly. If you don't hold them in the water long enough or you hold them too long they'll give bad results. Some even say to hold them level for so many seconds before reading.
    If the pH is good, then add a quart of the bleach, give it about 15 minutes and let them swim.
    Jul 2015
    Canada
    16
    According to pool math:
    Add: 12 oz of my 10.8% bleach AND 22oz CYA.
    I will retest and verify before doing anything.
    Jul 2015
    Canada
    16
    Quote Originally Posted by Bama Rambler View Post
    Hi Retested:
    Strips: FAC 0.5, TCI 1.0, ALK 80, PH 7.2, TH 100, CYA 0.
    Vials: PH 7.2, CL <0.2.
    So, I am going to pull out the floating puck and add 12 oz of the 10.8% Bleach and 22 oz of the CYA granules.
    Do I just pour these in with pump on or mix with water first????
    Thanks
    jasnovanorder's Avatar
    Jul 2015
    Hamilton Michigan
    201
    I have been mixing the bleach in a small bucket of pool water first before adding to the pool. As for the CYA the general response from here is to put in a sock in front of the return jet and let it dissolve that way. But wait about 30 min after adding the bleach
    Intex AG metal frame vinyl sides 10,400 gal. 3000 gph intex pump with 16" sand filter
    My Slam
    22,537
    Pour the bleach slowly in front of a running return and wait a few minutes for it to mix well.
    I wouldn't add any CYA until you have a good CYA test. You said that you've have trichlor in there for the last day. How much of it has dissolved?
    Also, have you added any other form of chlorine to the pool?
    Jul 2015
    Canada
    16
    Very little dissolved.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    this is a fresh refill, right? if so, add your CYA based on getting it to 30-40ppm
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jan 2014
    Buckeye AZ
    807
    if the pH is in the 7's you're fine for swimming. this cya/CH level will need to get sorted to avoid algae. But as long as you have even some FC you'll be fine for swimming today.
    Jul 2015
    Canada
    16
    What is weird is I added 12 oz of the 10.8% Bleach 3 hours ago......now I test it again and my CL levels are VERY LOW like <0.2 on the vial tester and less than 0.5 on the strip test??????? This is slightly a smidgen higher than what is was before I added the 12 oz of bleach?
    My pool has about 5400 gallons and it is a fresh fill using municipal tap water.
    I used the pool math and it said 12 oz would do it?????? Do I need to wait longer to get test???
    Thanks everyone.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Do you take baths in the water? first time use isn't much different than that, is it?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Raleigh
    357
    If you added it in the middle of the day with full sun, then it's quite possible that small amount was burned off quickly, especially in that you have no CYA (not yet dissolved)
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jul 2015
    Canada
    16
    Thanks....yes it was added mid day....will check tomorrow again.
    Quote Originally Posted by pabeader View Post
    Not much different at all. LOL.
    22,537
    The reason I told you to add a quart, was that I knew the sun would burn it off quickly and then if someone went swimming, that would burn off even more.
    You need to add a quart tonight if you haven't already.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    How long did it take you to fill the pool? Did you add any chlorine while it was filling?
    Jul 2015
    Canada
    16
    Quote Originally Posted by PAGirl View Post
    It took about a full day to fill. No, did not add chlorine when filling. Put the floater in with a dual action 3" puck (85% trichlor with algicide) That was in for almost a day or so....really did not dissolve very much at all...almost all there.
    So add some more bleach tonight? Guess I will take a reading first and see where it is at. Thanks.
    Jul 2015
    Canada
    16
    Well, just checked again and Chlorine is near zero, so threw in another 12 oz of the 10% bleach. Thanks
    Apr 2013
    North OKC Area
    300
    Stop letting the chlorine fall below two. Test and adjust hourly until chlorine holds at 5ppm unless you just really want to SLAM your pool.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
  20. Back To Top    #20
    22,537
    Did you add the CYA?
    As Dan said, you need to keep adding chlorine as often as you need to, to keep the FC above 2ppm.
    Since you already have the floater I'd put it back in there until it's used up. You can use poolmath to figure out how much CYA that will add to the pool and then only add more if needed.
